MAF & Intakes Issues on '03's ??
Old Sep 12, 2003 | 01:47 PM
brianc's Avatar
Over the past couple of months I've read about repeated MAF failure's on 00, 01 & 02's with the addition of Stillen, Frankencar or other free flowing intakes.
However, I don't recall seeing any 03's with this same affliction.
Are the 03's immune or is it due to a different/updated MAF?
TIA.
Old Sep 12, 2003 | 01:58 PM
FrankTheBunny's Avatar
My '03 has had a FrankenCar in it for about 5 months now without any problems.
But who knows, it could be just around the corner.... I'll be sure to post if it does.
Old Sep 12, 2003 | 02:05 PM
TitaniuMax03's Avatar
*knock on wood
Old Sep 12, 2003 | 02:36 PM
MannyNJ2k2max's Avatar
i have an '02 w/ no maf failure yet and had the
franken w/ k&n for +10k without cleaning it
Old Sep 12, 2003 | 03:26 PM
Cdriven's Avatar
So far so good!
Old Sep 12, 2003 | 03:49 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
the early 2k2 had very sensitive maf and therefore the failure rate was much higher. from my understand, they issued a tsb which part of involved replacing the maf with a newer one. i think some later built 2k2 had the new maf along with all 2k3. that doesnt mean that none of the 2k3 failed or that some of the updated mafs for 2k2 didnt go out but i believe it helped a great deal.
Old Sep 12, 2003 | 04:42 PM
soundmike's Avatar
Very sound, Mike
IIRC, i have a July 2001 build 2k2. Replaced my air filter with a dry-type... 31k and my MAF is holding up pretty well.
Old Sep 12, 2003 | 04:49 PM
MaxSE03's Avatar
It's because you have that factory freak Max. I don't know anyone else that gets 30mpg. So why wouldn't your MAF hold up as well?
2k3....Frankencar Intake......15k......No MAF Failure!
Old Sep 12, 2003 | 04:51 PM
soundmike's Avatar
Very sound, Mike
There's several other people here that gets 30+mpg. I guess it's because i live in Houston and my route is all highway.
As for the MAF, the OEM filter is oiled and took it out at 15k. I guess, if anthing, i really do have a freaky Max *knock on wood to not jinx it*
Old Sep 12, 2003 | 06:08 PM
Bluesbrekr's Avatar
Doctorate in Detailing
I've got a 2K2, built in 3/02. It has the 22680-AM600 MAF. I believe this is the same MAF as the 2K3's. I've had an Injen intake on for 2500 miles and no problems.
Old Sep 13, 2003 | 10:04 PM
studman's Avatar
This has been posted time and time again. Search the 5th gen forum by my name and the key word MAF. You'll find everything you need to know and then some.
Old Sep 14, 2003 | 06:48 AM
VQ35DE's Avatar
Studman your 3rd MAF was back to a 22680-6N201, did Nissan ever replace it with another 22680-AM600 yet or are they just going to wait for it to go bad too?
Old Sep 14, 2003 | 07:49 AM
clipse's Avatar
TIA.
brianc, Check out these two threads:
http://forums.maxima.org/showthread....hreadid=150052
http://forums.maxima.org/showthread....hreadid=234295
Old Sep 14, 2003 | 08:23 AM
studman's Avatar
They are waiting to see if it dies too. I do have it logged so it will be covered under warranty even though I am outside of the 3 year/36,000 mile warranty. So far, I've not had a problem on the 22680-6N201, but I also have the reprogrammed ECU from when I got the 22680-AM600 (the second time). So we'll see what happens.
I also have my O2 sensors logged as well, so I should be ok for a while.
BkGreen97
Apr 2, 2016 05:47 AM
ballerchris510
Sep 10, 2015 09:35 PM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
