If you are lowered with TEINS...
hey pplz........just wanna know the ppl who lowered with TEINS, what do you guys think and any comment?
and I have a question is if I am lowering only with springs for "now"....any disadventage/problem to the car?
I have Teins pair up with KYB GR-2s. The result is satisfied. With 2.2" drop at front and 1.7" drop at rear, these springs are the lowest for maximas right now. However, you can't pair them up with stock shocks because your ride will be extremely stiff. I had them for almost 6 months, there is no major or minor problems with the car. Corering ability is kick a.s.s!!!
here is the link
hope this helps
here is the link
hope this helps
Originally Posted by 92 SE-R 02 SE
Teins are great. They have the most even drop, which is why i got them. Ride is great, and the car has not bottomed out even with 5 people in the car...
Originally Posted by griffy2k2max
Nice lookin set up man! So you have had no scrubbing problems or anything out of the ordinary? I have H & R's, I still want to neutralize the fender gap just a little more.
Did you have to mess with the camber. I know that the 2.0 range is right at the limit of requiring camber adjustments
Thanks! No problems at all. Just go Slow over speed bumps!
(you need a "little" common sense though) An alighnment is not needed, 7000+miles on mine and I have perfect wear on the tires.
Btw
<~~~~~Didnt cut stops, and no I dont bounce.
Oh and one last thing
USE SEARCH! This has got to be thread #38 on Teins.
Originally Posted by 02'maxed-out
Teins mean A+ drop....and honestly not that bad of a ride compared to stock SE suspension
here is the link
hope this helps
here is the link
hope this helps
Originally Posted by ukeyman
Mine's dropped with Teins and stock struts. Love the look, the ride sucks. I knew this going in, just too excited to wait - very bouncy and unforgiving on EVERY bump. Just waiting for my GR-2s.
so should I buy the springs now? because i found those springs for a very cheap price........so......i am just wondering should I do it now.but then i heard if I only lower with the springs, the car will be very bounce and hurt?!! so stock can't support?!
ooo............that sux!
The stock struts dont have enough dampening force to properly control the higher spring rate of the Teins. What at means is when you hit a bump its gonna bouce and go all over the place.
Koni's are good and should outperform the GR-2's but read here:
http://forums.maxima.org/showthread.php?t=247474
MaxLvr21
Oct 17, 2015 12:11 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
