Best Muffler For 4th Genearation?
muffler
Originally Posted by WOODYMAX98
A muffler is looks and sound. No performance. I have a magnaflow and I love it, sounds great at low rpms and looks even better.
I recommend you to go to www.magnaflow.com and listen to the v-6 gti they have in the sounds section. Muffler as far as hp goes...I wouldnt expect more than a couple.
OK, after reading numerous threads and opinions and listening to the sound clips from magnaflow's website I seem to get the drift that magnaflow is the muffler to go with.
But which one?
There is probably a number of mufflers that would fit the 4th gen. But which one to go with?
Which magnaflow muffler do you guys have?
But which one?
his isnt worth 160 bucks dont go with that. I called magnaflow and they said that the gti exhuast system has a 2.5 inch exhuast and the canistor length of the muffler is 18" versus 14" of the most standard models like the one for sale above. I would look into model 14246 if I was you then get a nice tip welded on. Muffler should be about 85 bucks.
If you only want 2.25 inch inlets and outlets get the 14245. Keep in mind that the longer the canistor length the quieter the sound. Shorter is louder. As noted on magnaflows site it doesnt matter if their canistor is round at 14" or oval at 14" both will sound the same. I recommend getting the 18", I hear 14" sounds nice and deep with some minimal drone..adding that extra 4" of muffler should help clear that up. Up to you though.
muffler
Originally Posted by SLOW96MAX
That is what all the dyno tests show. Give or take a few.
I have heard good things about the sound from a 'Dynomax Super Turbo' muffler. They are not at all expensive either.
Do a search on that as well.
Originally Posted by 99MAXSE-L
doesnt work....
James92SE
142
Jan 2, 2024 09:23 AM
CAN-Toronto 97 SE BLACK w/ BLACK. PART OUT.
worldwiderecognized
Sep 24, 2015 06:56 PM
