Reverse Indiglo Gauge Installation
Hi, I just bought Reverse Indiglo Gauges and a wood bezel. Where can I find installation instructions with pictures. Is it hard to install your self without messing up your needles, how much do installation usally go for?
its not hard. first off, remove the entire cluster. two screws on top part of bezel. pull bezel out. will have to PULL. there are screws holding the actual cluster in. i believe there are three. two on top and one on bottom. pull aprt the cluster by pushing the pins down. then remove the front black bezel. the screws get romoved and are used in the holding down of the indiglo guauges. then u have to slip the indiglos under the needles. DON'T REMOVE THE NEEDLES OR MOVE THEM PAST THE SET POINTS. IE---DONT PUSH THE MPH PAST 120 OR THE TACH PAST 8000. after u do that get some double sided tape.(very thin) apply to places that cause the needles to stick. to test if the stick move the needles to like 90 on the speedo and let it roll back. and for the tack to 6k. find a wire spot for power. i used a wire tap on the dimmer switch. reattach everything and u should be good. anyqquestions feel free to email me. hope this helps. also try searching the forum by using the search option. good luck
BTW: nice car. might want to also ask geo1317. he assisted me on the install. actually he did most of it. thanks to him..
anyone else please help him if i forgot anything.
97_GXE
20
Sep 17, 2015 08:12 PM
