Z32 Caliper Conversion: Maxima SS lines or 240sx-300zx SS lines?
I had a quick question for those with Z32 calipers. Are you guys running Maxima SS lines? or the 240sx to 300zx lines? I've read that stock lines do work but then I also read that we should use the 240sx-300zx lines? Whats the different between the two? Is there a negative of using Maxima lines?
Any input would be appreciated. Thanks!
TJ
TJ
TJ
TJ
Do NOT run maxima lines. Get the 240-300zx conversion lines from www.heavythrottle.com
TJ
Will regular Z32 SS lines work? Or do I have to get the 240-300zx SS conversion lines?
TJ
TJ
TJ, how much did the upgrade cost you? Whats so good about the upgraded calipers if u dont mind me asking????? Im looking into it, but it looks expensive, kinda makes me wonder if i should be spending that much on break upgrades...
Umm... calipers depends. Its about $300 for already rebuilt calipers. You can get them pretty cheap (I've heard $100-$200) at your junkyard then do a rebuild. Rebuild kit is ~$60. Conversion SS Lines $100. Rotors and pads depends on what you get but roughly the same price as Maxima rotors and pads.
Without brakes you're car won't stop...
I also Auto-x ever so often as well.
MAXSE5SPD
Aug 23, 2015 12:06 PM
doobadoo
Aug 15, 2015 06:43 PM
RealityCheck
Aug 5, 2015 06:18 AM
