pics of custom trunks in 4th gen
Originally Posted by YellowOne
I was just wondering if anyone with a custom trunk on a 4 gen maxima could post there pics, trying to decide on a system set up. thanks
also check out Jason's (thebigsadler) car his trunk has a fiberglass system.
Hey I was just wondering how everybody braces their boxes in the trunk. Mine slides all over the place. I figured the easiest way would be to use a L shaped bracket, but I'm a little leary about that. Cause on one of my old cars I tried this old trick and I drilled 3 holes in my gas tank.
peace
I am planning on mounting my sub in the corner and using straps (I used to have an 8" tube in a convertible under the top)
Depending on where the best sound from my sub comes from, either between the rear wheel wells or from one wheel well to near where the tail lights are. Plus, if you need to access your jack and/or spare, you can easily undo the straps instead of carrying around a screwdriver to unscrew your L brackets.
[i was wondering if there is any chance you might have a write up or procedure of what youve done with the setup. i have never done a project like this before, and im about to begin on my 95 max. thanks.
if possible, respond to asdf154@aol.com.
-dante
-dante
Finkle
Sep 27, 2015 09:53 PM
95Maxi
35
Sep 2, 2015 10:37 AM
