I'M FINALLY IN THE 14s!!!!!!!
.189
2.314
6.317
9.606
75.20
12.441
14.842
93.18
humidity: 70
temp: 65
I ran this with: intake, ypipe, 41 lb stock gxe 15" steelies/tires in the front(26psi), removed spare tire and jack, 1/4 tank of gas
Launch and shifting technique: slipped the clutch at 2k. 1-2 @redline, 2-3 @ 6.4k, 3-4 @6.2k. From the start I thought my 60' was gonna be like a 2.7 cause I spun all through 1st gear, but I managed a 2.314.
Both of my other runs were 15-flat with 2.415 and 2.471 60's.
-Paul
2.314
6.317
9.606
75.20
12.441
14.842
93.18
humidity: 70
temp: 65
-Paul
Originally Posted by Ceasars Chariot
Paul...good work man !
Is it true for every .1 off the 60' = .2 off the 1/4(roughly)? If this is true than with a 2.2xx I can run a 14.6 just like you did.
and the same thing for the 15.0 with a 2.4. It will be 14.6 with a 2.2
-Paul
Originally Posted by bigdo26
nice run! with your 1/8 mile speed, i'm surprised your trap isnt higher... but great job!
My left front tire was leaking a little on the way there so I had to run that at 21psi. I set the right tire at 26psi. Might that be the reason why I only gained 17.98mph instead of 19-21.
maxima297
Sep 30, 2015 03:32 PM
