Oil Drain???
Old Sep 30, 2003 | 10:50 AM
Morfeus17's Avatar
Oil Drain???
To drain oil from the turbo, did you guys tap the oil pan??
Old Sep 30, 2003 | 10:57 AM
on_alert's Avatar
i tapped the lower pan, but it would be better to do the upper. Take the lower pan off and run a tap into the upper, just make sure that you dont leave any shavings in the sump.
Old Sep 30, 2003 | 09:36 PM
Morfeus17's Avatar
Thanks. I was told to get a second pan for this. Not sure why.
How are you getiing oil in?? Straight from the pump??
Old Oct 1, 2003 | 10:05 AM
on_alert's Avatar
remove your oil pressure sensor and replace it with a tee. put the sensor on the branch, then use the run to go to the turbo. if you get a second pan, then you can do the work to the pan without having your car down.
Old Oct 1, 2003 | 10:26 AM
Morfeus17's Avatar
OK. Thanks. I'll keep you posted.
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
Forge277
Jun 13, 2016 09:26 PM
05RLS2
Apr 14, 2016 11:49 AM
