Idle questions...
Idle questions...
Upon startup the car will idle around 1100-1300 (depending on length of time the car has been without a start) and will idle there for about 2-3 minutes until it starts to rev up and down between 800-1100 for about a minute or so. Even if I start driving the idle will continue to stay high and I can basically keep the car in 1st gear without using the clutch and it's almost like an automatic idle. After about 5 minutes of letting the car sit and idle it will drop down to 700-800 and idle normally from there on out.
We did not make a 1/8" bung for a vacumm line in the piping before the mafs and I do have a check engine light (13-02) for a MAPS/Baro Sensor.
I have taken the car to Nissan and had the code run, but the sensor it talks of seems to be fine, although I haven't tested it throughout and I haven't tried to replace it.
I honestly don't think it has to do with the 1/8" bung we left out and tied into the vacumm line T's but I do think it has something to do with that MAPS/Baro sensor code. It was on as soon as the turbo was installed and sometimes goes away, but will usually come back within a day. Besides checking out that sensor and possibly replacing it, any ideas?
jason
jason
Originally Posted by JAY25
Jason is better to be safe then sorry, try and see if you can weld a small bung for that vacuum T, adapter you may need it.
I mean I can do it, if I can find that steel piece, but lowes/homedepot and etc dont have anything that small.
Originally Posted by thebigsadler
I still have yet to find a piece of steel with a 1/8" hole. Let alone stripping off all the powdercoating and welding it up.
In my MEVI theres a little piece that one of the hoses run to, I believe is one of the fuel pressure hoses. Run a T off one of the other vacuum hoses and see if that makes the CEL go away vice tearing up your car. Thats what I did used a plastic T.
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
