Got pen ink stained on my door!!! (exterior)
Well, a couple days ago at school a pen apparently bursted in my pocket, and when I went to open my car door, the ink from my hand (that was resting on the door got on the car. Now there is a little stained blotch that is copper in color. I tryed using car soap to get it off, didnt work. I scraped gently with my finger nail and it smeared it around some, but nothing really changed. What can I do to get this off??
What is 3M compound?
Some kind of tape?
Some kind of tape?
Originally Posted by EteRnity059
Coke will work too. It's very acidic, some people use it to clean battery terminals.
anyways, so cola wouldn't damage my clearcoat?
#1 way to get pen ink out...use rubbing alcohol.
it's safe on the paint...dab some on a clean cloth and blot it off. if u don't believe me write on your hand and get it off w/ alcohol..you'll see it'll just come out.
i'm serious.
also rubbing compound and waxes might smear the ink.
i'm serious.
Originally Posted by Y2KMaxGXE-R
I'd vote against rubbing compound. 1st solution is a bug and tar remover, 2nd solution rubbing alcohol. 3rd solution is a paint thinner-be very careful with that.
Do not use paint thinner, I stripped the H3ll out of my paint one time. I had to get the whole quarter panel repainted.
it's called "paint thinner" for a reason.
don't know why 1/2 you guys are telling him to use that.
Originally Posted by asu174
Sell your car and get a Camaro. That is really your only option at this point.
LT1 or LS1? Z28 or SS? The black on black loaded '97 Z 6spd just didnt do it for me man.
Originally Posted by nice95GLE
OK all BSing aside the best way I know of to remove ink stains from a car exterior is
1. Lemon Juice (use a fresh lemon)
2. Hairspray (nothing to strong)
Those should work fine.
Good Luck
Good Luck
the reason why hair spray works is due to the alcohol content in it.
The alcohol worked, but I'm hoping saturating a towel area and soaking it a bit does better than rubbing like I started, but out of the mass I had I only have two small areas left. I will get compound for those and get the rest out. Thanks all
After 13 years it finally came out?
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
