Need some help! Replaced Axle, noises not gone
Back in June I needed a passenger side drive axle so I bought one from www.Raxles.com. I installed the axle and everything was fine until a few weeks ago when I started hearing some loud scraping/grinding sounds coming from the front passenger side of the car. There were also some very high pitched squeeking sounds. All the sounds were in proportion to my speed up until about 30mph (the slower I drove, the more drawn out and slow the noises became). Also, there was only noise when the car was hot and I had been driving for several minutes, stop and go.
Since I have Sprint springs I figured they caused the Raxles axle to go bad so I called Marty and had him send me a replacement axle under their lifetime warranty.
I installed the new axle on Saturday and today was the first day I drove enough to get the car nice and hot (brakes, engine, etc). The car was making the exact same scraping/grinding/squeeking noises as before the new axle. Obviously it isn't the axle....
Anyone have any idea what could be making these noises? I don't think it is the brakes, could it be the bearings? The fact that it only happens when the car is hot kind of confuses me.
Whatever it is I'll be able to fix it myself, but I just need to figure out what to replace.
Thanks for any info in advance.
-Tony
-Tony
-Tony
-Tony
u have an auto or 5spd?
possible tranny/axle bearing?
It's possibly the bearing, and that's what I thought after I had replaced the axle. A little bit after the bearing was replaced, the noise was back. The diagnosis: Axle again. And of course, I noticed that the other axle's boot is done, so I need to replace both axles now...aaarrrgg
I have an auto. The noise is coming from out by the wheel, not under the car near the tranny. This leads me to beleive that it is the front wheel bearings. I found some instructions on motorvate.com on how to replace them so I think I'm going to do this. Everyone I've spoken to seems to think these noises are caused by bad bearings.
Tony
Tony
Tony
Tony
Did you check and see that the metal dust cover to the brake rotor is not touching? that happened to me three weeks
Tony
No I didn't check that. I guess I will but I doubt that's the problem. The noise only comes when the car and brakes get hot????
Tony
Tony
Originally Posted by Cutlr7
I would bet that metal shield or wheel bearing
I had a similar problem and after a couple of runs with baggs on the freeway and braking alot the noise went away
dont know why. The car is sitting now and the noise is back again, I may change the brake pads and go from there.
I'll jack the car up tomorrow night after work and check it out. I doubt I'm lucky enough for it to be the heat shield. I think the bearings are only making noise when they get hot and expand. If I drive the car hard for about 10 minutes, the noise is there, otherwise nothing. Anyone know a good online site to buy the front right bearings? Would a local Pep Boys or Autozone carry something like this?
I'd like to replace them ASAP...
Tony
Tony
boomerbrian
Nov 8, 2015 05:10 PM
kingw323
20
Oct 21, 2015 08:36 AM
Starrider
Sep 17, 2015 07:26 AM
kirkhilles
Aug 8, 2015 10:53 AM
