235-55-17, Will They Fit An 20th Anniversary Maxima?
Old Oct 4, 2003 | 06:54 AM
Topview01's Avatar
Going tire crazy like eveyone else. Potenzas are crap, Michelen Pilots are in the lead, but I read great things about Dunlop A2's but in Toronto the closest size to what we need is a 235-55-17, anyone tried this size? Will it work? Does it mess up the speedo?
Thank you all in advance
Hello Cheif.....................Max235-55-17 yes or no an 01 20th Anniverssary
Old Oct 6, 2003 | 09:04 PM
valitare's Avatar
It will probably only change your mileage to read about 5-6 mph lower than you are really going. I have a 2k3 and I have 225/50/17 on there now and test fit 235/45/17. The larger fit and did not rub, but when you plus size you should go up 10mm on the section width (first#) and down 5% (second#). That way the 5% lower on the section height gives you a similar height and a little wider tire without rubbing. There are Michelin Pilot Sport A/S in 235/45/17, and Falken 225/50/17. These are great tires and if you want something for ultimate grip the BF Goodrich GKDW's in 235/45/17 are I hope that helped a little. Good luck to you.
CRizz
41
Jun 7, 2021 05:42 AM
2k11ApexEvo
Mar 30, 2016 06:54 PM
Finkle
Sep 27, 2015 09:53 PM
wyobbagy
Aug 15, 2015 02:28 PM
Bruceharrison
Aug 9, 2015 07:56 AM
