installing ring gauges...
Old Oct 5, 2003 | 01:13 PM
'97 5spd's Avatar
does anyone have any experience w/ installing ring gauges, i heard it's hard to do since there are 4 screws behind the cluster panel and that the glass is fragile. If anyone has ever done this please let me know.
thank you
- '97 5spd
Old Oct 5, 2003 | 01:31 PM
driver824's Avatar
its easier then u think... first remove two screws from the top bezel. the bezel surrounding the cluster then gets pulled out with light force from the low center. then the top part has to be pulled out and the bottom has to be squeezed out over the steering wheel. after the bezel begins to pull out, take the three connecting wires out. then the bezel shold pull out. then the cluster is set in by three srews. two bottom. one top. pull the cluster out and then disconect the wires to the back.. i believe three again.. then the cluster should come out. use a screw drive to push down the plastic tabs to remove the plastic cover then use thumb tac to hold downt he rings. my rings dont fit 100% ok. there actaully to small but i mad do.. it looks hot. any other question feel free to ask. email if u prefer. ill chec that more. good luck later..
Old Oct 5, 2003 | 01:34 PM
Ravq's Avatar
This may help a little.
http://www.maximadriver.com/modules....rder=0&thold=0
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
2kmaximel
Sep 16, 2015 03:19 PM
DBear
Sep 14, 2015 08:33 PM
Johnny9595
Sep 3, 2015 05:18 AM
