CV Axle Replacement
Old Oct 7, 2003 | 12:34 PM
MN_Maxim's Avatar
CV Axle Replacement
Hey All,
I've read alot about this and am now going to order parts to do this myself as I see that my boot has totally separated and I hear the clicking noise when I turn the wheel. Parts are relatively cheap for what kind of part it is and I hear that it's fairly easy to do. But my question here is that I see a bunch of axles designed for a slip or non-slip differential...how can I determine if my diff is slip or non-slip? I had kinda assumed that they all were non-slip.
Thanks in advance for the help!
Ryan
Old Oct 7, 2003 | 03:38 PM
dr_blaqueman's Avatar
man I am in the same boat as you, can anybody help us out?
Old Oct 7, 2003 | 03:40 PM
Noslen's Avatar
hehe, I WILL be in the same boat.
Old Oct 7, 2003 | 03:43 PM
PoePoe2797's Avatar
If you have the I30 tranny, you have a LSD, which is called a Limited Slip Differntial. Maximas (stock) dont have those.
Old Oct 14, 2003 | 11:27 AM
MN_Maxim's Avatar
I did find an answer online...from Nissan Parts Store "The drive axles of the Limited Slip Differential can be identified as having a double set of splines on the driver's side inboard joint stub shaft."
Old Oct 14, 2003 | 11:55 AM
mzmtg's Avatar
Minister of Silly Walks
www.raxles.com
Best axles out there for our cars.
Old Oct 14, 2003 | 08:41 PM
ChrisA's Avatar
Ryan,
Please post how you made out with this job if you started it yet.
I'm going to be doing mine in the next week so I'd love any tips or problems you came across while doing it. Also, where did you end up buying your axle? I'll probably just get a rebuilt one at Advance Auto Parts for the $80 or so after core (driver side front, 95 SE auto).
Chris
Old Oct 15, 2003 | 04:05 AM
I30tMikeD's Avatar
Originally Posted by MN_Maxim
Hey All,
Ryan
All USDM Maximas were non-locking or as you put it "slip" differentials. There is a stamped metal plate on the passanger side firewall under the hood. The tranny code is listed there. The series starts with an R and will either end in a V or A. V's are locking and A's are non-locking. Only place you will find a locking differential around here is a I30 or a Canadian spec max. Not all I30 or Canadian spec max's have them.
Old Oct 15, 2003 | 05:15 AM
Ceasars Chariot's Avatar
Old Maxima Legend
yeah you right !
Originally Posted by mzmtg
www.raxles.com
your darn right ! www.raxles.com the only way to go !
Old Oct 15, 2003 | 08:57 AM
Taxvictim's Avatar
Wait, are you saying that the RS5F50V is NOT a VLSD? I thought the V was for the limited slip? I have a '96 I-30t with the RS5F50V transmission, and assumed that was the viscous limited slip differential. (It might help if I actually understood the mechanical differences between the two.)
Old Oct 15, 2003 | 09:41 AM
I30tMikeD's Avatar
locking = VSLD
Old Oct 15, 2003 | 01:26 PM
RA030726's Avatar
I'm nutty for Nissans
Also don't forget if you have ABS or not. If you have ABS you need ABS axles, but if you dont you have ABS then you can use either axle.
Old Oct 15, 2003 | 03:42 PM
perfectmax's Avatar
Yelp, i just took it up the butt by nissan. they charged me $450 to repack and rebuild the axles.
Old Oct 16, 2003 | 08:55 AM
ChrisA's Avatar
do you have to have an alignment done after changing an axle?
Old Oct 16, 2003 | 07:09 PM
MN_Maxim's Avatar
I plan on starting it this weekend...was wondering...how much were the axles from www.raxles.com?
Old Oct 16, 2003 | 08:21 PM
BEJAY1's Avatar
Conecarver
I still have a spare in good condition if anybody wants just to replace.
http://forums.maxima.org/showthread.php?t=246544
Old Oct 17, 2003 | 08:25 AM
ChrisA's Avatar
i picked my up at Advance and hope to do it next week sometime. it was about $90 after core and has a lifetime one free replacement guarantee. the car only cost me $800 and has 180,000 miles so hopefully i won't have to replace it more than that!
vingodine
45
May 21, 2016 12:46 PM
kingw323
20
Oct 21, 2015 08:36 AM
Starrider
Sep 17, 2015 07:26 AM
PH98I30
Aug 20, 2015 04:25 PM
classymax420
Aug 6, 2015 06:35 PM
