bosch vs japan brand for distributor cap and rotor
nissanpartstore.com has both . the bosch combo will run about 20 bucks wheras the other option called the "Japan" brand will be about 35. I dont think they would make any difference but has anyone had bad experience with bosch other than the spark plugs on ve's....unrelated ? has anyone replaced oem carpet? if so how much did you pay and how difficult was it to take seats out and everything else that it entails
I'd probably just get the bosch, or just go down to Napa and buy their OE replacement parts.
Also it seems people either have a good or bad experience with bosch plugs and their VE's/etc. Personally I've never had a problem with Bosch in a variety of motors, including VE's, however I replaced the Bosch Platinums that came in my car with NGK V-Power Coppers. I used Autolite 45's in the mustang, but if I were to do it again, I would probably use the NGK's, although the autolites are burning just fine.
All in all, with the stock VG ignition, you really arent going to have a problem with sparks jumping terminals and whatnot, so I'd go with the cheaper cap and rotor, I haven't heard of anyone having problems with them.
It's my soap box and I'm not getting off!
Originally Posted by todamax
dude, the OEM ones are aluminum. I've seen other posts here about problems with the non-OE caps/rotors. I don't see why one wouldn't buy a Nissan one.
OE used the NGK laser platinums on the VE for a reason! They don't like to just spend money!
You should use motorcraft plugs in a domestic ford vehicle not autolite
Cap and rotor just try to make sure that they have brass contacts not aluminum
The thing is, both the VG and VE ignition systems are top-notch stock. Tweaking this and that, replacing this and that doesn't really help and in most cases causes other problems.
Just don't apply more's law to the spark plug gap though
You know, the stock cap/rotor set up isn't that much more expensive. Take a look.
http://www.courtesyparts.com/J30_tuneup.html
I don't know if it's common or not, but it seems like everytime I have replaced the Dist. Cap and Rotor (with aftermarket brand available at AutoZone) they develope small cracks in the plastic near the posts. The cracks don't appear to go all the way through to the top side, but it makes me wonder if the OE one will do the same thing..
londonflu
40
Sep 25, 2015 09:11 AM
boomerbrian
Sep 2, 2015 03:46 PM
