Basic question about alignment
Old Oct 12, 2003 | 07:12 PM
steelymatt's Avatar
When you get an alignment, do they align the steering wheel so it is centered and then adjust the toe, camber, etc...
or is the steering wheel centered some other way?
Old Oct 13, 2003 | 11:47 AM
AtlantaMax's Avatar
When they drive your car up on the alignment rack, they SHOULD straighten the wheel as best as possible. Then, they put this bracket type thing that rests between the steering wheel and the seat to help hold the wheel straight. Then they do all of the adjustments to the alignment (toe, camber, caster, etc).
As long as they keep the alignment settings on each side of the suspension exactly the same, and the wheel does not slip or accidentally turn while they are doing the adjustments, it should stay straight.
However, everytime I get an alignment, the wheel always seems to be turned just slightly to one side or the other.
Old Oct 13, 2003 | 12:00 PM
roastduck88's Avatar
When you get an alignment done they will straighten out the steering for you. If it is not straight take it back to them and they will correct it for you. On alot of cars the caster is not adjustable, the toe and camber is though.
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
06maxima55
Sep 28, 2015 04:29 PM
ivorton23
Sep 26, 2015 09:47 AM
