Which Cat-Back should I buy
Hey whats up, I've been looking at Cat-backs and im not sure of which one i want. I dont want one that's going to give me a loud annoying sound like hondas with exhausts. I want something that'll sound deep, more like a mustang sound. I know Cattman and Stillen are both loud so scratch that. So what's left is OBX, Greddy and Apexi. How do these cat-backs sound? And also what are the prices? Thanks for your time guys , i hope you can help me.
-Chris
-Chris
http://maxmods.dyndns.org/?MaximaCatbacks you need to choose your own based on price, what your looking for, noise level, etc
I looked at the OBX cat-back and i see that there are three different ones, Type DTM, H and B. Do these have different sounds? hp gains?
Originally Posted by maxNYC
yep, yoru answers are here... just READ
i think you want the B...i dont know if all the different types will fit your car. im almost sure for some reason the H wont fit. try doing some searches, research and look around. hope that link helped
I just got my H OBX cat-back. It fits perfectly.
It has dual resonators on the B-pipe, and a nice 4.5" tip (not rounded though
)I'm just having a hell of a time with my catalytic converter's bolts. Two of them rusted and broke in half (inside the threads)! Looks like I 'm going to have to either buy a new one, or go to a muffler shop and get them outta there.
i remember some post when someone was asking if they should get the B or the H, and the h was recomended against. dual resonators sounds quiet, and the 4.5 tip doesnt sound like my style
, i guess its up to you
, i guess its up to youSO you're saying the B is recomended over the H? Does the B have dual resonators?
How does it sound? And how did it fit? Did u have to make any adjustments?
Originally Posted by Mahstylez
Did anyone have any problems with the OBX as far as fitment?
Well, I finally got mine all on (**** that catalytic converter).
The only problem I've had so far is that the muffler tip isn't sitting perfectly between the bumper cut out. I think if I get under there, and mess around with the hangers (mabye bend them) It'll be just fine. But for the moment, the exhaust is LOUD, but not raspy. Just LOUD and DEEP.
4k rpms>me.
And yes, my exhaust is dual resonated. It's the type-H. I took some pics yesterday, and I'll post them on here ASAP!
Dan
Originally Posted by mistachink
yo I had tha same problem, the cat back bolts are welded not rusted!
Well, after the bolts BROKE OFF in the cat, I took the cat to a muffler and machine shop, and they both were charging at least 60 bucks an hour, so I was like "screw that, I'll just go to home repo and get me a metal drill bit and try to get them out myelf. I ended up drilling them out with a 5/8" (might be 5/16, not sure) Cobalt drill bit that was made for metal. That combined with my amazing arm strength (hey, I work out), I got those bishes drilled out. I ended up putting in a 5/8"x1" bolt with a washer on one side, and a lock washer and nut on the other. It's holding pretty good right now, but it's only a temporary solution IMO. I'm probably either going to buy a resonated straight pipe (no FL emissions>me) or a carsound cat.
How's the sound with the resonated straight pipe? Is it better than with the stock cat?
4k rpms>me.
Dan
4k rpms>me.
Dan
-Chris
with dual resonators, there would be no gains...more stuff in the way, IMO only thing you would notice is different noise (deeper)
correct me if im wrong, but resonators dont go INSIDE the piping, they wrap around it with glass packing to stop some of the sound resonation, to deaden the exhaust sound a bit, in which case, exhaust flow wouldnt be bothered at all, so i dont think ur right when u say no gains .... more stuff in the way, but what do i know
well, there could be gains... 2-3 hp maybe, i thought dual resonators wouldnt perform as well as a straight pipe. correct me if im wrong (and probably am)
haha im not sure, but i don't think it would cause restriction, just noise reduction, any experts care to chime in?
then why would a b pipe make gains if there was no resonators in the pipe restricting it? http://forums.maxima.org/showthread....5&goto=newpost
b pipe makes gains because the piping is a large diameter than the stock piping
Originally Posted by indigomax
i have already installed my Apexi WS...man!!! deep sound and the best HP with y pipe and intake. Contact Ange..he sold me the catback for 412 shipped.
how would something on the outside make the sound quieter from the pipe?
ok think about it like this, if u look at the more quiet exhaust systems out there they have a distinguishing mark, and thats usually a larger exhaust canister than a louder exhaust system which has a smaller exhaust canister(not in length, but the diameter) . what a resonator does is takes the same glass packing material (type of "padding"thats in the muffler) thats in the muffler, and puts it on another section of the exhaust which in turn deadens the sound and makes things quieter. Mufflers are like big resonators themselves they stop the sound from being too loud, some mufflers are better at it than others because of the type and amount of packing they use.
hmmm, sounds good... i think my plan is to get a Y pipe and straight B pipe (prolly no resonator) and then keep the stock muffler... a lot of gains, but not too loud, and if its too quiet for my liking, i would pop on a new muffler. would an un resonated B pipe get too buzzy?
SXN, the sound waves coming from the combustion chamber are constantly reflecting off the walls of the exhaust piping until it exits your exhaust.
A resonator has glasspacking and other materials that make the walls of the pipe in the resonated area. These materials better absorb the sound waves and therefore reflect less of the sound waves. This results in a reduction of the intensity of the sound leaving your tailpipe.
The sound deadening materials in a resonator are held in place by a metal mesh. When air travels through the resonated section of the exhaust at pressure it experiences more tubulence as it moves along the mesh that makes up the walls of the resonator. Also some of the exhaust will move through the mesh into the sound deadening materials and back out again thus causing more turbulence. This turbulence leads to a slight loss of horsepower over a midpipe of the same dimensions that doesn't have resonators. However I feel this loss is small and insignificant and therefore I chose to have two resonators in the exhaust I chose for my maxima.
http://auto.howstuffworks.com/framed...austtheory.htm
jusread that before you start talking about exhaust systems
When does the exhaust start to get loud at 4k rpms? Does it sound like a stupid honda with exhaust? lol sorry i hate that honda sound. And did you feel any hp gains?
-Chris
-Chris
I just put it on, so it's going to be a little loud for a few weeks until it breaks in a little bit. But, it's deep, and a little raspy when the engine is cold, but when it heats up, it's nice and deep, and when you hit 4k rpms, the exhuast amplifys the intake sound, it's awesome. When I first installed it and turned it on, I couldn't hear my subs. After the second time I started it, I could hear my subs again. It toned down alot even after the second start up.
Did you take the silencer out?
