trip to JWT
trip to JWT
I visited JWT on tuesday to have my computer tuned. On their new dyno which hooks up to the hubs the car hit 398 FWHP and fell off at 5500 rpm because the fuel pressure dropped off. Jim said I probaably would have hit 450 with the proper pressure. Has anyone else encountered this problem? We tried a nismo fuel pressure regulator but the fuel press. still didn't hold. What's going on? I am using 370 injects and a walbro 255 hi fo fuel pump.
could you list your mods? :>
Thanks!
EDIT: OK did some quick research..........your sig
"96 I30, Built engine, built tranny, 12lbs of SCed boost, 75 shot N2O, aftercooler, and H2O injection
no rice but plenty of meat!!"
3.5 VQ oil pump
could you compile a complete list of exact mods please!? :>
EDIT2: I think you need bigger injectors
I agree, it sounds like you need to go to 550's.
Nice numbers, I think you need bigger injectors.
I30krab, I am currently rebuilding my 98's VQ30DE. I am trying to decide on what oil pump to go with. I saw that you are using a VQ35's pump. My choices are a toga high volume pump or the VQ35's. What would you suggest I go with? The toga costs $129 and I don't know about the VQ35's price. I know this is off the threads topic but I appreciate your help.
Did you by chance ask whether or not they were considering producing an ECU for the 98-99 Maximas? Or did you get a business card? None of us has been able to get in contact with JWT for a LONG time regarding this issue- and anything would help about now....
Call Joe at Infinity of Scottsdale for the latest price!
I do know that Ben always answers the phone and he knows whats going on in their shop.
Originally Posted by Prodeje79
you have the JWT cams and valve springs , right?
Thanks!
3.5 VQ oil pump
Thanks!
3.5 VQ oil pump
Jim and Clark think the walbro 255 pump and the 370 injectors along with the nismo fuel pressure regulator should easily work, we just have to make sure everything is working properly and especially check out for voltage drop at the fuel pump. This is a common problem.
Originally Posted by Stephen Max
Yowzah! What maf are you using? Are you using constant 3 bar fuel pressure or do you use an fmu?
I don't use an FMU because the pressure is managed by the ecu. As of now I aguess it is 3 bars.
Originally Posted by MardiGrasMax
Weak pump, maybe.
What was your fuel pressure at 5500rpm
Acording to my math your injectors are maxed out, time for 555cc.
Right now we're checking these parameters. If we can't fix the problem without going to 550 injs, forget it! Buying and installing these are too expensive and time consuming, and I will have to suffer with 400 horses at the front wheels!! It could be worse.
I definitely would go with the VQ35 oil pump. It drops in like it was made for our motors and I get twice the oil pressure compared to the VQ30. You know it works, why try another unproven pump?
I have so many mods that it's hard to remember them!
You have the cams and valve springs, right?
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
