pcv is a B**ch
Old Oct 17, 2003 | 05:29 AM
gonzo's Avatar
pcv is a B**ch
anyone else have a problem getting that tube off of the pcv valve??
the other end of the rubber tube is connected to a metal tube that doesn't budge and since there's only about 6 inches of rubber, it makes things really hard.
any tips for getting that bastard off???
Old Oct 17, 2003 | 05:33 AM
big_al's Avatar
You have to unscrew the 10 mm bolt that holds the metal pipe/bracket. If you don't you'll bend the pipe.
Old Oct 17, 2003 | 05:51 AM
Confused's Avatar
Permanent Maxima.org Resident
panel popper is your friend.
Old Oct 17, 2003 | 06:25 AM
Jatan's Avatar
Unscrew the little bracket thing and push it up a little, then pull the hose off. The PCV valve was stuffed in good so I used pliers to pry it out since I was going to throw away the old one anyways. Took me like 2 minutes
Old Oct 17, 2003 | 07:25 AM
gonzo's Avatar
thanks yall
good to know all this AFTER i scraped up my hands.
gonz
Old Oct 17, 2003 | 10:06 AM
WizzaMax's Avatar
well its pays off to read the simple stuff like that panel popper idea...that works wonders....
Old Oct 17, 2003 | 11:03 AM
ivelweyz
you'll have more trouble putting it back on...
bumpypickle
Sep 20, 2015 08:22 AM
lowpost99
22
Sep 2, 2015 04:38 PM
maxinout93
Aug 20, 2015 02:17 AM
puch
Feb 25, 2002 03:28 PM
Dave B
Aug 28, 2001 09:47 AM
