F: 18X8.5, +30, R: 18X9.5+35, 4th Gen
Old Oct 20, 2003 | 02:20 AM
ardika's Avatar
..with 225/45/18 for all four corners. Will this combo fit the car well?
Most importantly, will this setup clear the big brake kit from Stillen/etc.?
I understand that our cars will not need bigger tires in the rear, but a friend of mine is interested in buying a wheel set with the spec above.
Is this safe (load rating wise, tire to rim fitment, and handling)?
Old Oct 20, 2003 | 10:38 AM
Nealoc187's Avatar
SLOW
Originally Posted by slammed95
That tire size is very wrong for those wheels. For the 8.5" you need at least a 235, should be 245/40/18. And the fronts should be between 35-42mm offset.
For the 9.5" you need at least a 255, should be 265/35/18. With that wide a wheel in the back, you need a 38mm offset.
The clearance for the brakes will be determined by the design of the wheels.
Agreed. 225s on a 9.5" wheel will look retarded, if you can get the bead to even seal. 225-40-18s are recommended to be used on a 7-8.5" wheel.
Old Oct 20, 2003 | 02:30 PM
ardika's Avatar
If you guys are suggesting those sizes...man..... it would be a heavy setup, especially in the rear.
235/245 in the fronts and about 245/255 in the back then.....
I should go and punch in the numbers at the tire calculator to find out about ratio.
Thanks guys!
MAXSE5SPD
Sep 17, 2022 04:00 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
MplsMadMan
Sep 11, 2015 07:54 AM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
