different circumference for rear and front? bad idea?
Old Oct 21, 2003 | 10:24 PM
Roman-dude's Avatar
what will happen if I put tires with diff circumference in the rear and in the front? I'm guessing that since they are not directly connected (for the lack of a better word), it would be ok. what do you think?
I have the stock fronts (205/65/15) that are fine but the rears need to go. I wanted to get all for in 225/60/15, but have a chance to get two 225/55/15 Michelins cheap, so I am thinking of putting them in the rear abd keeping my current fronts for now, and then changing all later...
so, how does it sound?
Old Oct 21, 2003 | 10:39 PM
Roman-dude's Avatar
Originally Posted by slammed95
On stock wheels it's pretty pointless. There are a few reasons to have different diameters, but only when going for a performance-oriented setup.
Use the same size all around.
wider tires will give me better traction, i am not doing it for any other reason. also, i am asking because this will give me an opportunity to get tires for a fraction of what it would cost to replace all 4...especially that the fronts are still good.
thanks
Old Oct 21, 2003 | 11:06 PM
Roman-dude's Avatar
225 will give you slightly better traction, but with a 55 series sidewall it will flex a lot under cornering. Tires are the only thing that hold your car to the road, and could save your life. How much is that worth to you?
a lot, obviously. 225/55/15 are "recommended", among others, 15" 55 series on 6.5" rims according to the tire & rim assc. one would think it should be safe if it's "recommended", as opposed to "permitted"......no?
Huttig2009
Sep 25, 2015 03:31 PM
JoshG
21
Sep 4, 2015 09:04 PM
homeyclaus
Sep 3, 2015 06:15 PM
doctorpullit
Aug 20, 2015 05:15 PM
laparka66
Aug 6, 2015 09:36 AM
