Z-MAX?? any feedback on it? should i dump it in my car?
Hows everyone doing? Just bought a 89 Maxima SE..top speed 125 :-(......its all good though......a max is a max....i seen something on tv called "Z-MAX". I wanna know if any of you guys put that in your max and what results did you get. "Z-MAx" says that it will make your car last longer and restores all seals and stuff..Please if you guys can just gimme sum feedback on it.....id really appreciate it. THanx Again.
Top speed 125? lol I'm sorry your 4 door front wheel drive family sedan is not up to big block chevy standards.
Unless you live in Germany there shouldn't be a problem.
Best additive I think is Auto-RX(www.auto-rx.com). It's an oil additive that cleans out the whole engine. Check the fluids section of this forum it is recommended.
I wouldn't put Z-Max in anything. The FTC investigated Z-Max and through independent testing found that Z-Max is essentially colored mineral oil. They also found that Z-Max caused extensive bearing corosion.
IMHO, all of these additives that claim that they bond to metals and save gas while giving you more horsepower are just plain snake oil. Not to mention a waste of money.
Change your oil on a regular basis with quality oil and you should not have a problem.
dont put any addatives in , Izzy put some fuel injector stuff in and ended up replacing an injector.
btw at 16 you dont have nearly enough experience to be driving about 65mph, let alone 100+ take it easy before you kill someone. and then your posting that your max is gone.
Besides stick with FI cleaners that don't spend all their money on advertising.
and NEVER believe these "NEW (insert part here) in a bottle" claims They are short term fixes with long term consequences.
I just deposited my Zmax refund from the class action lawsuit.
yeah, i've not heard many good things about that stuff.
guess i'll give everyone my speed as well. i hit 125 in 4th gear at around 5000-5500 i believe. hit redline then shifted into 5th and still had 1000 rpm to go. I believe i heard someone say they were clocked doing 143 mph by a cop. He was in a vg 5-speed, same as mine.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
altome15
Aug 10, 2015 07:05 PM
