Can't get alarm to disarm (I've searched)
Old Oct 28, 2003 | 05:54 PM
87MustangGT's Avatar
I just bought a 92 GXE. When trying to unlock the car from the driver's door, the alarm goes off when I open the door. Also, turning the key in the door both ways after the alarm goes off does nothing. However, if I try to unlock it from the passenger side, it works fine. Also, I can shut the alarm off if it is sounding from the passender door as well.
From what I gathered in the Search on here, you're supposed to be able to shut off/disarm the alarm from the driver's door, so I'm really confused...
Old Oct 28, 2003 | 06:34 PM
espimax's Avatar
if you just wan`t to disarm the alarm for good all you need to do is open the hood look for the hood alarm pin , pill off the two cables wrap then together and the alarm will never arm again.
Old Oct 28, 2003 | 06:56 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
sounds like the door trigger is no good
Old Oct 28, 2003 | 07:34 PM
I don't want to disarm it for good - every little security bit helps...
How do I check the door trigger for sure? Where is it located/what does it look like? I know I know, I should just get a Chilton's or something...
Old Oct 28, 2003 | 07:41 PM
ghostmax's Avatar
i have the same problem. i'm going to resolder the door lock timer joints this weekend (after exams) to see if it helps. you can disable the alarm from the trunk too fyi.
try turning the key clockwise twice in the driver's door. if it doesn't unlock all doors after the second turn, then you probably need to resolder just like i do. not a big fix.
Old Oct 28, 2003 | 09:05 PM
Burn MF Burn's Avatar
enter the door code on the keypad ?
Old Oct 29, 2003 | 06:25 AM
I'll try the trunk thing and the two-turn thing later on...
Any way to reset the keypad code? Or find out what it is now? I just bought the car from a dealer and he has no idea anything about its history, so...
Old Oct 29, 2003 | 06:42 AM
nismo_s13's Avatar
i have instructions to reset the door code if you wish.. i just need to find them
Old Oct 29, 2003 | 06:59 AM
That would be awesome nismo! Please let me know as soon as you find them...
Old Oct 29, 2003 | 07:00 AM
internetautomar's Avatar
mod or sell?
Key pad master code is on the control box by the glovebox. Do a search and you should find a post with better details
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
bigdogsteve
Jan 31, 2018 04:18 PM
lrb6805
Sep 24, 2015 05:03 PM
