Removing Front Seats - AirBag Connector
Somehow my other post didn't get posted. So here it is:
Going to do some noise control tomorrow and I need some guidance in regards to removing the front seats since they have some airbag connector/sensor. This is what I think I should do. Comments are welcomed:
Before removing seats, disconnect battery, pull Airbag fuses, uplug airbag connectors under seats.
After completion of work, put seats back, plug airbag connector, put fuses back, connect battery.
Also, just in case I get the Airbag light after all this, how do I reset it without having to take it to the dealer?
Thanks,
Pedro
Thanks,
Pedro
Good question... I wish I found out that answer before I pulled my front seats when I installed dynamat. That damn blinking light is driving me insane!!! Is there a way to reset it without going to the dealer? I tried unplugging the battery. OH well I'm intrested in this too.
-Dennis
-Dennis
Finally found something using the search . Last night the search function was kicking you out. Two different procedures. Let me know which one works.
If your airbag light is on (or flashing)... try this.
By the way, use a stopwatch to count.... the timing must be accurate in order for it to work.
Open the driver's door. Note the rubber covered button, a button which is
pressed by the door when the door is closed. This is the Driver's Door
Switch (DDS).
Turn the ignition from OFF to ON. Press the DDS at least 7-12 times within 7
seconds after turning the ignition switch ON. Turn the ignition OFF.
Close the driver's door. Start the engine. (It varies from 7 -15 times on pressing the DDS)
-----------------------(2002-2003?)-------------------
1) Turn IGNITION on (but don't start car)
2) After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.
3) Wait 4 seconds
4) Turn IGNITION on (but don't start car)
5) After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.
6) Wait 4 seconds
7) Turn IGNITION on (but don't start car)
8) After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.
9) Wait 4 seconds
10) Turn IGNITION on (but don't start car)
11) Wait 3 seconds
12) Turn IGNITION off
13) Wait 2 seconds
14) START Car (the light may be blinking slower than before)
15) Wait 3 seconds
16) Turn IGNITION off
17) Wait 3 seconds
18) START Car
Pedro
Switch (DDS).
3) Wait 4 seconds
6) Wait 4 seconds
9) Wait 4 seconds
11) Wait 3 seconds
13) Wait 2 seconds
15) Wait 3 seconds
17) Wait 3 seconds
18) START Car
Pedro
Thanks,
Pedro
Thanks,
Pedro
Note this is only for 2k2. 2k0-2k1 might be different.
So you are saying. Just unplug them without disconnecting the battery, plug them back and you should be fine on a 2K2.
Pedro
Pedro
Originally Posted by Kojiro_FtT
That's what I did. Although, I don't have side airbags... that could be different. Do you? Well, then let me put it this way: just unplug it without diconnecting the battery, plug them back in and you should be fine if you have a 2k2 without side airbags.
see what happens, hehe.-Dennis
Originally Posted by iLLin-2k1
So you only have one plug under your seats? Well if you have power seats then you have just 2? I'm pretty sure there is still a sensor hooked to your seats, side airbags or not. Pedro just try it
-Dennis
Great. Don't have side airbags. So only two connectors under front seat (sensor, power seat), one connector under passenger (sensor). Ready to do my project tomorrow. Thanks.
Pedro
Pedro
vingodine
45
May 21, 2016 12:46 PM
kirkhilles
Aug 8, 2015 10:53 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
NO MORE FLASHING LIGHT
