Recommended tire pressure???
Hey what do you guys recommend for tire pressure for 1/4 mile racing? Should there be more in the rear tires or no? Also what should the tire pressure be for daily driving (it's time to check mine)??? Thanks.
Originally Posted by bigdo26
you can lower it some, with stock tires it wont make much of a difference. probly better to keep close to regular pressure (32 psi or so) in the front, maybe pump the rears up to 40ish.
kinda overgeneralized. i'm goin on what my buddy told me, that on regular street tires, deflating them wont make much of a difference. lower pressure will create more contact area, but then it'll make more resistance up high, so things will get cancelled out. i've tried lowering the pressure down below 20 psi and also keeping it at 35 psi, on the same night of course. actually got better traction at stock pressure than at lowered pressure. Also, my trap speed was about .1 lower with the lowered pressure, which to me shows there is more resistance at higher speeds. My 60' times throughout the night were almost the same, and times didnt vary much.
your right, lower tire pressure will hurt trap speeds a bit, but the extra traction will give better ET's. I am more worried about ET than trap. Lowering your 60's will give greater advantages then the disadvantage of more rolling resistance. Getting out of the hole is what good times are all about.
Lowering the tires pressure is only useful if a person is spinning their tires too much. If spinning is not a problem then I would not lower the psi.
Ya, ET would be affected more by the 60' times. I'm also speaking from the view of an auto tranny, so with a 5 speed i can see that traction would be more important still. I ahvent had much of a problem spinnin my tires on takeoff, so maybe thtas why pressure hasnt made a difference
Lowering pressure on street steel belted radials actually decreases driving traction...the belts take up the slack and bulge the center of the tire towards the center (inner part) of the wheel...
This is why if you drive around with low tire pressure all the time the outside edges of the tire wear the most...the footprint is totally uneven (with majority of the pressure on the outside). Do a test. Lower your tire pressure to 20 PSi, go out to the nearest street, and do a little burnout. You'll notice the tread patteren is missing either all of or the majority of the center section...with two dark strips where the outer tread is.
Well, laid a little rubber this morning. I could not see any significant sign of the tread pattern missing the center section. Maybe a tad. Then I went to the track and pulled a 2.14 60' at 25psi.
Fernando
What do you mean by "track tires and wheels" ? Are they DOT approved for street use slicks?
JoshG
51
Sep 21, 2015 10:41 PM
Serotta33
Sep 17, 2015 12:14 PM
sdotcarter
Sep 2, 2015 09:53 PM
