How can I tell if my car is Fed or CA emissions?
Under the hood
There should be a white sticker showing the emissions diagram. At the bottom of the sticker, it should say something like either "This vehicle meets Federal emissions standards" or ""This vehicle meets California emissions standards". At least it did on the 4th Gen.
Originally posted by My 4DSC
I looked under the hood...
I looked in the door jam...
Didnt find any info.
The easiest way is to pop the hood and look. Someone around here ought to be able to tell you how to visually tell the difference. As I recall, there are some wires coming out of the air intake area -- and you can tell what system by the number of wires.
/aac
Engine Computer
I've got a 1997 & we couldn't find a computer for it at all because we didn't know it had California emissions but on the computer it had a sticker on it that said it, so if all else fails then look at it. (Center Dash)
Starting with the 2001 model, there are no longer any "California" cars, they all have the same emissions equipment, which is essentially California.
On a car prior to 2001, look at the options tag located under the hood on the firewall. On a 4th gen, this is an aluminium plate rivited on the passenger side. On a 2000, this is a white plastic sticker just to the driver's side of the center.
On the tags you will see the VIN number and below that is the options line. Count over to the 12th character.
U = non California, USA
V= California
N = Canada
V= California
N = Canada
V= California
N = Canada
V= California
N = Canada
The US government created different standards than they had been using and ordered car manufacturers to start using them on the 2001 model year vehicles. The new specs were modeled after the California specs but were slightly different and more strict. Technically they are not California cars but using the term allows some people to better understand.
There are no longer two versions. There is only one emissions standard used in the U.S. so the "Do you have a Cali car or a Fed car?" does not apply to cars built since 2001. One part fits all.
You want to get the "50 State" model, YG5/CA. But before you order it, check the tag under the hood and verify that you have the letter U. Then you can call Cattman and ask them which one. Also ask them why the photo for the 2 y pipes are the same.
Fed or California
I need an o2 sensor but need to know which emissions my car is.
Thank you!
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
