Rewire Fog Lights Failed
Old Nov 16, 2003 | 01:23 PM
I30swimmer's Avatar
I was rewireing my for lights so they are on when the driving lights are turned on well basially the instructions i followed told me to splice the wire from the relay and connect it to the side marker and it should work. Well the problem now is that the drving lights dont work and NONE of the four side markers work and when i turn a corner using my blinker the cornering lamps dont work either. so basically im screwed. IF ANYONE KNOWS WHY THIS HAPPENED OR HOW TO FIX IT please help me out here thanks!!
Old Nov 16, 2003 | 01:59 PM
kgb006's Avatar
YOu can start by checking the fuses, hopefully you just blew a fuse if not you shorted something in that case you got big problems.
Old Nov 16, 2003 | 02:07 PM
nismotech's Avatar
Do you have pictures of how you rewire the wires?
Old Nov 16, 2003 | 02:34 PM
I30swimmer's Avatar
well i looked at my fuse box and nothing seems out of the normal so i might have shorted somthing out should i just take it into the dealer and have them deal with it IM WAY OUT OF warentee though so it shall be a ***** load of money and no i didnt take pics because when i was doing it thats when the problem happened and then i changed everything back to the way it was to try and fix it
Old Nov 16, 2003 | 02:42 PM
SEdge
mmmmm punctuation
Old Nov 16, 2003 | 02:49 PM
AKM2k5's Avatar
j/k.... we need pics and tell us exactly what you did....
Old Nov 16, 2003 | 07:09 PM
00MaxSE's Avatar
Pointy Elbows
The same exact thing happened to me when I did mine. The problem was a fuse. Check under the hood. It was one of those, not one under the dash.
J.
Old Nov 16, 2003 | 08:01 PM
nismotech's Avatar
Someone is going to get OWNED! By the dealer!
Old Nov 17, 2003 | 08:04 PM
I30swimmer's Avatar
WELL problem solved it was a fuse under the hood not under the dash thank GOD it was JUST A FUSE otherwise my *** was gone have no cash to pay for fix thanks for all the help. issue resolved
Old Nov 17, 2003 | 10:52 PM
kgb006's Avatar
Old Nov 18, 2003 | 06:33 AM
00MaxSE's Avatar
Pointy Elbows
What'd I tell ya?
Old Nov 18, 2003 | 06:37 AM
SEmy2K2go's Avatar
Go BUCKS!!!
So did you leave it wired up as stock, or go back to the fogs wired in with the headlights?
The Frye
Sep 2, 2021 11:03 AM
mvm062
Nov 30, 2020 09:00 AM
ballerchris510
Sep 10, 2015 09:35 PM
Maxima30
Sep 7, 2015 06:13 PM
sdotcarter
Sep 2, 2015 09:53 PM
