aftermarket wheel weight vs oem wheel weight
Old Nov 19, 2003 | 04:18 PM
maximadave's Avatar
detailerdaveb@gmail.com
I know the 5th gen stock 17's are about 50+lbs each and I just found out that my Antera 18's are 28.5lbs ea. Is this the average weight of aftermarket wheels?
Old Nov 19, 2003 | 06:38 PM
drewm's Avatar
It's a little on the heavy side, most 18s are around 25lbs.
The stock 5th gen 17s should weigh about 24lbs I hear, the 50+ is including tires.
Then again my 18x7.5 TE-37s weigh 16lbs each
Old Nov 19, 2003 | 07:13 PM
maximadave's Avatar
I'll have to take my tire/rim off and put it on the scale.
Old Nov 24, 2003 | 06:02 PM
gar777's Avatar
many wheel weights, OEM and aftermarket, can be found on:
http://www.wheelweights.net/
a good goal for "lightweight" wheels is 1 pound per inch of diameter, though most "lightweight" are slightly over this. also, the wider the rim the heavier the wheel. Our bolt pattern, 5x114.3, is one of the heaviest, requiring a fairly wide and heavy midsection.
9aj9
Apr 5, 2020 12:11 AM
captchaos
Mar 15, 2016 12:18 PM
aminus21
Sep 12, 2015 04:53 PM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
