Fiberglassers...any tips?
Old Nov 21, 2003 | 02:20 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
For those of you that do your own fiberglassing (shavedmax)...can you recommend any sites out there with tips or tricks or anything like that? Also maybe even where/what products you love or hate?
I have a few projects i'm working on that will eventually lead into fiberglass work. I have things i'm going to practice with for awhile until i can get decent. Gracias
Old Nov 21, 2003 | 02:21 PM
Jeff92se's Avatar
I'm needing a caw
Do it completely naked
Old Nov 21, 2003 | 02:23 PM
voltman's Avatar
What about stray hairs?
Old Nov 21, 2003 | 02:24 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
damnit...thread hijacked already...there's a lot of that going around lately
Old Nov 21, 2003 | 02:45 PM
thebigsadler's Avatar
what are you fiberglassing exactly?
if you are doing a trunk setup, it is all about the framing. ie-what you build out of wood that will be fleeced and later glassed. there are a lot of little things that can help you avoid big problems and speed up the process, but its a lot different for doing body work or a stereo setup..
Old Nov 21, 2003 | 02:52 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
eh...it's mainly interior stuff so no fabbing/framing would be needed. i eventually will redo the trunk but that work i'd want to save until later when i have experience...
Old Nov 21, 2003 | 03:01 PM
if you are just doing interior pieces for paint, you are basically working with resin mostly and not fiberglass. what interior pieces? and are you making custom stuff or just making it paintable?
if you are going to just paint stuff, you can use spray gel coat that holds up better too heat, takes less work and holds the clear better.
Old Nov 21, 2003 | 03:09 PM
Shadow's Avatar
For interior work, Jason is right don't use too much fabric. Using mostly resin will be easier to work with, and require less finish work. The fabric is pretty much there for structural purposes. But make sure that you are very exact in your mixtures of resin/catalyst. If you mix it wrong, it either won't dry or can warp from drying too fast. And if you are coating interior parts in glass, make sure the surface is prepped properly.
Old Nov 21, 2003 | 03:11 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
good stuff jason and jeff...jason i shot you an email. thanks guys...
Old Nov 22, 2003 | 06:07 PM
shavedmax's Avatar
if it's stuff like trim pieces then no need to use resin, sand and fill the grain either with bondo or primer( a good high build primer nand wet sanding will do the trick) if you are dooing anything soft(ie dash, door panels etc, you NEED to reinforce it with glass or it will crack! if you are making kick panels just cover your floor with plastic, put aluminum foil where you want the pod, so it holds shape, lay some glass and then start to shape it. anything else just e-mail me. with out knowing exactly what u are dooing it's tough to give good advice, pretty much like jason said
Old Nov 22, 2003 | 10:32 PM
Shadow's Avatar
Oh, another thing just in case. If it's anything that has to fit against something else, make sure you check for clearances since the glass will add thickness to it. I've seen some people crack a dash when they shut the door too hard because they didn't take into account the extra thickness of the glass.
rbuswell
Nov 12, 2016 04:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
dcam0326
Sep 18, 2015 04:52 PM
sdotcarter
Sep 2, 2015 09:53 PM
Justin Kroll
Sep 2, 2015 11:06 AM
