clutch thickness...
Old Nov 24, 2003 | 03:30 PM
michaelnyden's Avatar
clutch thickness...
how thick should a nissan oem (not key value) friction disc ---ie. clutch be when brand new for our cars......does anyone have a good pic of what the disc looks like when brand new....just curious....
Old Nov 24, 2003 | 03:31 PM
Jeff92se's Avatar
I'm needing a caw
both are probably about the same thickness. the nissan fsm has specs for this.
Old Nov 24, 2003 | 03:55 PM
how do you know how worn the clutch is by looking at it? are there any common signs by looking at it....as you can tell, i have it outside the car right now...
Old Nov 24, 2003 | 03:57 PM
Jeff92se's Avatar
I'm needing a caw
http://www.cybrrpartspro.com/Chilton...961CH07_8.HTML
You have to measure it. Off hand, if it's been 30-40k, might as well replace it unless you plan for a fidanza in the future.
Old Nov 24, 2003 | 04:07 PM
it says 0.3mm thick...but is that new....or just acceptable thickness, what are they saying?
Old Nov 24, 2003 | 04:10 PM
Jeff92se's Avatar
I'm needing a caw
0.3mm of material above the rivets is very thin. That's probably the min you can have. What does YOURS measure?
Old Nov 24, 2003 | 04:58 PM
can't measure it with a ruler...have to find something else to measure it with...i think im just gonna take this to a mechanic and see what he thinks...do you know if the friction disc on courtesy nissan is the key value or the real oem one?
Old Nov 24, 2003 | 05:00 PM
Jeff92se's Avatar
I'm needing a caw
Stick a toothpick in there and mark it. Then measure it with a ruler or something equally as ghetto For the clutch parts on Courtesy's site. I'd CALL specifically ask.
Old Nov 24, 2003 | 05:20 PM
its slightly above 1.5mm
Old Nov 26, 2003 | 02:27 PM
Jeff92se's Avatar
I'm needing a caw
I don't know what new specs are. BTW. Try not to start a new thread for every new related question. Thanks
Old Nov 26, 2003 | 02:38 PM
well nobody answers my first questions....so i have to be presistant
Old Nov 26, 2003 | 02:39 PM
Jeff92se's Avatar
I'm needing a caw
Why not be prudent and visit an auto store and browse though their service manuals? Or buy a Nissan FSM? For work like this I can't believe you don't have one already. How do you know what to torque everything down to????
Old Nov 26, 2003 | 04:46 PM
KWheelzSB's Avatar
Get the OEM NIssan clutch CHEEEEEAP!
Daikin Clutch kit - 4th Gen. Maxima's OEM clutch - (NOT Key Value)
Get in touch with John (aka: .org member "Clutch King") at Direct Transmission Parts in NY.
800-989-8726
His part #: 06044
The kit includes the friction disc, pressure plate, clutch release bearing & alignment tool - everything you need.
I won't quote his price online here, but it's much less than Courtesy N., or anywhere else I found - trust me on that. I received the clutch kit just the other day as promised & highly recommend this seller/.org member.
-K-
PS: My new replacement clutch measures 9mm thick from the face side of the friction surface to the backside of the friction disc. The thickness from the friction surface to the highest rivet measures 3mm, so apparently that 3mm is the "new" specification, not the minimum safe thickness. Anyway, hope this helps.
. . .and yes, buy a FSM or Hayne's manual - well worth the investment.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
