Upgrade stock woofer/amp while still using oem wiring?
Just wondering...I did a search and didn't come up with anything.
Is there anyway we can upgrade to a more powerful amp and subwoofer while still keeping it mounted in the rear deck and stock wiring?? The stock is alright but I'm looking for something with a lil more kick.
r u talking about the stock 8 inch sub woofer???
and do u want to hook it up to the stock headunit
if yes then u can ....you just have to get an amp with speaker level inputs and then hok up the subwoofer to your amp and thats it
Originally Posted by LithiuMax
20. Haha...
That is crap. I suppose it wouldn't matter while I was at it if I replaced the woofer too? Has anyone done this before? I know a bunch of people have put wooferboxes in their trunks and I'd like to but I really need to room for work stuff.
Come on, we need more responses. I'm looking at doing the same thing. I looked on Crutchfield.com and saw a few 8" speakers but I'm sure which one's will work. I hate not having a search option. I guess I'll have to make a donation...
Are you serious??
im planning to do the same thing ....i would assume your best bet would be to get an 8 inch subwoofer and drill it in and get an amp that will power it and thast it nice clear soundsing bass!!!!
i can wait to do the saem thing
-J
And if you want an 8" woofer to replace the stock one and fill in with some midbass, look at a woofer that covers a large range, like 30 Hz - 3.5 kHz.
$59 - Sony XSL836 @ 30 Hz - 3 kHz
$198 - Alpine SWS-0840 @ 32Hz - 2.5kHz
You get what you pay for.
You will probably need an 8" baffle from Crutchfield, since these woofers are not free-air rated. I could not mount my 8" Pioneer cause the hole was too small. (I get that alot when I try to mount things
) You need to cut the metal piece, or just buy an MDF board from Home Depot, and cut it to hold the woofer. The metal piece is crap anywayz...G
Originally Posted by 02MaXiMa_GLE
This is INCORRECT. You can't just use an amp with speaker-level inputs on a stock Bose system. You need some type of special converter. I would search, if I could... but you can probably find more info in the FAQ sticky. I think it's the PAC-OEM NISS-x kit, or something like that... (the kit & the adaptor are sold separately)
G
G
Actually that is INCORRECT as well, you can just add female RCA outs at the radio itself. The run the RCAs to the amp.
-_Don
-_Don
-_Don
cutting, hacking, and jacking.G
G
how can u tell me you cant hook up an amp with speaker level inputs into the stock bose when b4 i bought my tv i had my subs hooked up to the bose thorugh speaker levels inputs into my amp and it worked perfectly
-J
Not on a 2k2+ with Bose... unless you know something I don't... in which case, please do share, Don! Unless there is some kind of kit available now, it would probably require a lot of "custom"
G
cutting and hacking is how the pro's do it, and its as pro as ur gonna get anywhere else, why waste ur money on an adapter when u can just use the preamp signals from the head unit and wire them into rca's? its so simple and it sounds great
-J
-J
And as far as tapping into a Full-Range speaker Level input: many here say it will cause damage to your Bose headunit...plus the quality isn't great at all. I've read quite a few posts. Then people just end up getting the adaptors and rewiring it anywayz... Of course, I can't search so I can't find any related threads.
nismos14: The 2k2 Bose does not spit out RCA preouts... (not the Navi one anywayz)
Please correct me if I'm wrong, people. This is information that I've collected from older threads regarding the 2k2 Bose (and Navi combo)
G
Originally Posted by nismos14
never said it has RCA preouts, the wirign thats there is a preout, its just not RCA preout, its wired preouts to the bose amp
OEM outputs from Bose (Clarion) HU are actually variable line level outputs.
OEM line level outputs work with aftermarket amps WITHOUT the need for a special adapter/converter.
OEM line level outpus can be easily converted to RCA outputs by cutting the output wires from the HU and attaching RCA plugs on the ends (a relatively simple process).
Now a few questions:
If I wanted, could I just tap into the signal lines going into the OEM Bose amp on the rear deck? I'm thinking I could use the existing/OEM signal wiring (instead of running my own RCA cables) and continue to also use the Bose amp to drive some speakers while simultaneously using an aftermarket amp to drive other speakers - Bose for rear and aftermarket for front.
Similarly, would this idea work with the subwoofer signal coming out of the Bose amp if I wanted to use the OEM signal but upgrade my sub amp and speaker?
Thanks!
Originally Posted by ABS
#1 OEM outputs from Bose (Clarion) HU are actually variable line level outputs.
#2 OEM line level outputs work with aftermarket amps WITHOUT the need for a special adapter/converter.
#3 OEM line level outpus can be easily converted to RCA outputs by cutting the output wires from the HU and attaching RCA plugs on the ends (a relatively simple process).
5th gen - Aftermarket AMP with stock Bose possible???
Then the "experts" that have done this already will chime in and give you an exact answer, and a correct solution. Describe that you want a FULL RANGE amp setup, not just an amp for some aftermarket subs.
I think soundmike and studman have done this... but I can't search for their threads.
Also, Kloogy had it done at a shop.G
I think #2 & #3 are INCORRECT. Someone should start a NEW thread with the Title:
G
u could only use the bose amp to power the stock bose speakers. the reason being is that the bose speakers run at 1 ohm. there are no other automotive full range 6 3/4 speakers that run at 1 ohm. this being the case, the bose amps would put out minimal output because of the higher resistance in the aftermarket speakers
Posted from Maxima.org App for Android
The Frye
Sep 2, 2021 11:03 AM
MR2 T'd
Jul 9, 2021 05:06 AM
dvcamp
Sep 18, 2015 10:17 AM
Justin Kroll
Sep 2, 2015 11:06 AM
