Can I use a Hayden tranny cooler as an engine oil cooler?
Originally posted by Whitemax
I saw a post about it a while back but never saw the response and I can afford $50 over $350 anyday....
last i checked the oil does not get circulated through the stock cooler. the tranny yes..but oil i don't think so. you can see if u can find a adapter to put on the oil filter and do it that way..but good luck finding someone that makes one.
Dan
Re: I asumed I could connect it the same way as Stillens.
How is that one connected? Does anyone have the Stillen oil cooler?
the main part is the adapter..you can use just about any cooler out there.
Dan
hayden 597 oil cooler i think
I think thats the model number. And what it is is a Hayden 404 cooler the same as the tranny one. It comes with an adaptor and tubing. Its a complete kit @ $80 over Stillens $375.
However, i ran into a small problem. The Maxima oil filter does not fit. The gasket diameter is a little too small. And it would cause an oil leak. Purolator emailed me some other filters that would fit with the 20mm thread. My nextt concern is the length of the new filter plus the sandwich adaptor. I'm afraid if its too long the lower suspension arm might hit the filter. So, tonight if i have time i will duck tape a cardboard tube around my stock filter and check it after a week and see if it got hit.
pktaske
May 6, 2016 07:49 AM
kjlouis
Oct 3, 2015 05:29 AM
pktaske
Sep 4, 2015 08:40 AM
