Wilwood Big Brake Kit with Stock 17" (AE or non-AE) wheels
Old Dec 3, 2003 | 08:49 AM
twotone's Avatar
Wilwood Big Brake Kit with Stock 17" (AE or non-AE) wheels:
Has anyone gotten this to work?
What size spacers did you need to install?
What length studs.
I have someone telling me 30-35mm, but I remember 4th gens doing this with 15mm. I know the offset is different and the hub is different but I expected 20mm max..
Please anyone who has done this or knows how to make this clear please let me know. I want to get the kit on this week.
Chris
Old Dec 4, 2003 | 12:46 PM
twotone's Avatar
Bump!
Old Dec 4, 2003 | 01:00 PM
BigDogJonx's Avatar
Id help you but I dont have the stock wheels to test this for you. Unless someone in my area drove to my place I can try to test fit it and give you an answer cause I got the Wilwood BBK on my joint.
Dixit
Old Dec 4, 2003 | 08:46 PM
Mick Max's Avatar
Wild at Hurt
PM Galo
I think he has the Wilwoods and has experimented with different wheels and spacers. He is having some custom spacers CNC'd right now. He is a great guy.
Old Dec 4, 2003 | 08:48 PM
twotone's Avatar
Originally Posted by Mick Max
PM Galo
Yeah.. I PM'd him.. and have heard nothing back.
If anyone talks to him please send him this way
Old Dec 4, 2003 | 08:52 PM
twotone's Avatar
Dixit
Which kit?
Original GD that I got mine are
4 piston Superlites with 13" (12.9") 2 piece rotors
Precision has since come up with a new 2k-2k2 kit that is
4 piston Dynalite with 13" (12.8") 2 piece rotors
With the kit I have now... (12.9") I have been told it will take approx 1.25-1.5" (30-35mm).... that's a lot of spacer.. no spacer kit I know is that big for Max.
Any suggestions??
Now the newer kit I hear is thinner.. calipers are about 10mm on each side thinner..
Don't know what the spacers needed would be .. maybe 20-30mm? I'm guessing here.
Any help would be great though.
Old Dec 5, 2003 | 06:32 AM
twotone's Avatar
Dixit
Here are the templates.
My Current Precision Kit
New Thinner Precision Kit
Old Dec 5, 2003 | 06:58 AM
defsquad222's Avatar
Twotone, I have 99 Max and posted same questions. Galo is very helpful...here is the link to my topic, it may help you out
http://forums.maxima.org/showthread....hlight=spacers
Old Dec 5, 2003 | 07:33 AM
twotone's Avatar
I've PM'd Galo before with no word back.
I just did again.
Hopefully will get some help.
But I have a different kit then you so clearance might be a bigger problem.
And from what I have been told it will take 1.25-1.5"(30-35mm) to clear....
So I don't know if I should swap kits.. but mines already pained
My Wilwoods
Old Dec 5, 2003 | 07:33 PM
Galo's Avatar
Maxima Pilot
Hey, guys...please forgive me in not answering but....I was traveling and doing some other stuff, basically have not been into the Org site in almost four days....
I PM'd both of you....
Two-Tone.....if you wanna chat on the phone tomorrow, I'll PM u my phone number.....
Galo
Old Dec 6, 2003 | 05:57 PM
twotone's Avatar
Galo
Car is over at Maximum Tuning getting few things straightened out.
I will get the brake kit back when I pick up the car next week.
I will do the measurements on the kit when I get it back and chat with you.
I don't know about shaving the A-arm (what problems might this cause?)
My kit originally came with hats that were alot higher and precision sent me the shaved ones (lower profile).. don't know if this helps.
Here is a link to my superlites
Old Dec 7, 2003 | 03:12 PM
Galo's Avatar
Maxima Pilot
Okay..it looks like you have the modeified hats indeed.
I was the first one who got the PB kit, and for that kit they did all the measurements on a loose, unattached axle/spindle....because I was traveling I did dnot get to play with the kit for about three weeks, then I discovered the interference problem with the A-arm, which PB had not discovered because their axle/spindle did not have an A-arm attached to it!
I took a Dremel to the outer edge of the A-arm and shaved a little more than an eighth of an inch from it, absolutely no problems. There's plenty of material there.
Along with the new, shallower hats -should be about .625- you should have alse received two new small aluminum spacers which allow the caliper assembly to be properly centered on the new shallower hats.....did you get those as well??
If you have all these pieces, you should be able to clear your stock wheels with the H&R 5mm spacer.
Matt93SE
May 24, 2019 02:58 PM
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
