switching to synthetic???
Old Sep 19, 2000 | 08:52 AM
JeffO
1st...is Mobil 1 0w-30 okay?
also,
do i need to use flush to prep the engine.
any recommendations?
Old Sep 19, 2000 | 09:08 AM
Jeff K's Avatar
The switch should be fine...
Other then draining out the old and replacing it with
new synthetic everything should be fine.
There are synthetic blends of half & half so I would not worry about the change.
Old Sep 19, 2000 | 09:29 AM
1MAX2NV's Avatar
Don't use 0W30. Stick with 5W30. Don't use heavier grade of oil on a newer car.
also,
Old Sep 19, 2000 | 09:54 AM
Paul6speed's Avatar
Re: The switch should be fine...
Be careful about the blends. Some of them are only 5% synthetic. Make sure it shows a high percentage of synthetic. I'm now using Mobil 1. Since I change my own oil, it's roughly the same as paying someone to change it with dino oil. Anyone know where to get Mobil 1 cheap?
Old Sep 19, 2000 | 09:59 AM
Jeff92se's Avatar
I'm needing a caw
Either go 100% synthetic or 100%->
dead dino juice. Blends are a waste of time IMHO. Remember if you use Mobil 1, it's not designed for extended drain intervals so don't run it any longer than you would a dino oil.
Old Sep 19, 2000 | 10:22 AM
The New CLIMAX's Avatar
I thought you were supposed to change out synthetic oil
every 5-6K miles as opposed to 3K with the dino oil. I heard that you don't get the benefit of synthetic oil if you change it out every 3K miles.
Old Sep 19, 2000 | 10:29 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Answers to the questions....
Stick with 5W-30...no need to risk the VQ unless ambient/environmental conditions insist....
As for the engine flush/synthetic/etc. visit this post (which, BTW, is one of Jeff92se's favorite posts)
<A HREF="https://maxima.org/forums/showthread.phtml?threadid=398">https://maxima.org/forums/showthread.phtml?threadid=398</A>
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
lrb6805
Sep 24, 2015 05:03 PM
