place racing cold air intake.. or then injen...
i was reading and it was saying that the injen isnt a real CAI ..... does this have any downfalls if i were to get this.. or should i get the placeracing CAI.. which would benefit me more ( i dont mind cutting a hole )..thanks
Well the Place Racing CAI is a real true CAI as its filter sits in the fenderwell away from the radiator and engine bay. On the negative side you are prone to sucking in water going through a puddle/flood or such. The Injen is considered to be the best looking CAI, and it's filter sits right in front of the radiator under the battery compartment. I wouldn't say it's a true CAI but there is plently of cool air down there, plus you aren't prone to sucking in water unless you go through a really deep flood. Plus the sound is unbelieveable sounds like a V8, maybe I'm biast because I have an Injen, lol.
pr- better performace so you'll get maybe 1-2hp more then the injen.
injen-much louder then the pr intake, shiny and showy.
intakes are for sound and show. they do so little for performace. get the injen easier install.
As far as the PR outperforming the Injen just because is sucks in cooler air, that theory might not be entirely true. The PR might be getting cooler air, but don't you think that the Injen might have access to a bigger volume of air altogether?? IMO, where the Injen filter sits gets more air than the fender and behind the battery. And besides when you're rolling the air in the engine bay is much cooler than in stop and go traffic.
Originally Posted by IwANnAMaX96
That statement is too general. Reason intakes don't do much for 4th gens is because the main bottleneck is the USIM. It would be the same thing as buying a cat-back before a y-pipe.
When it comes down to it, injen and place racing are going to flow the same. Anyone who tells you that you are going to gain an extra hp because of the cooler temps is incorrect because they are not accounting for the effect of the resonance. The only place where the cooler temps will help may be on a hot track day. You may end up lasting longer before getting heat saturation. Many people have switched to a hybrid intake which is middle ground between the CAI and HAI. This is essentially a CAI midpipe with a popcharger attached.
So it's really about personal preference. Neither one is going to "flood" with water easier than the other, they both sit at about the same depth.. And i've checked, the inside of that fender stays pretty damn dry, even when it's very wet out and you are driving through puddles. Just dont freaking sink your car and you'll be fine. I personally like the look of the PR intake over the Injen. I would say that the PR makes just as much noise or more than the Injen.
Disclaimer: I have had a PR cai for more than 2 years and have recently purchased a popcharger to go hybrid. (try that with a Injen, good luck heh)
Dude, why did you quote me??
I wasn't arguing about which type of intake was better. I was just presenting a theory of mine about the Injen vs. Place Racing, which is the point of this thread if you didn't know. If you read the post I quoted, you would know where I was getting at. I've heard it all about the CAI/Hybrid/Pop-charger debate so you're talking to the wrong guy. Try reading next time.
KabirUTA13
19
Oct 17, 2015 02:15 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
Keyno McMike
Sep 21, 2015 07:18 AM
pears
Sep 18, 2015 05:25 AM
