Oil Pressure Warning Light...Help
Just replaced the fuel injectors on my 92 Max, 158K. Shortly thereafter, the oil pressure warning light came on. If I accelerate, it flashes, or it I hit a bump it does the same thing. It could be an electrical prob, but just wanted to see if anyone had run into the same thing!
Use your ears as a diagnostic tool and listen to your engine. As stated the oil light is rated to come on about 5 psi but I'm sure if you had 5psi you will also be getting A LOT of engine noise, valve tapping etc. I've ran out of oil twice with my VE and trust me it's not a pretty noise. If you have no engine noise it's probably a loose connection. The oil pressure switch is located behind the alternator. Enjoy
Candiman is right it is not a pretty sound... Take the worst sounding VTCs you can think of and multiply that by alot... metal on metal contact does not sound good at all... if the oil light stays on and there is noise check the oil filter to make sure it is still on tight
By the time you've heard the knocking it's too late , The damage has been done
There was damage done, Chances are nothing to major though.
I'm not sure how resistant to knocking the VE motor is
I know my old 305 was extremely resistant.
Ran it out of oil numerous times, Filled it back up and she was quiet again
litch
123
Jan 4, 2024 07:01 PM
05RLS2
Apr 14, 2016 11:49 AM
