scrubbing
Old Dec 19, 2003 | 01:14 PM
mjax10's Avatar
scrubbing
what causes my rt front or my left front to rub when taking tight turns i've recently installed front strut bar thinking that would help a little but has not. My next guess would be to add front and rear sway bar?? Also it feels like I'm riding on pure rim when taking corners 225/40/18's.
Old Dec 19, 2003 | 02:43 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
what is the offset of your wheels?
Old Dec 19, 2003 | 03:10 PM
mjax10's Avatar
7.0 offset
Old Dec 19, 2003 | 06:23 PM
Bman's Avatar
Originally Posted by mjax10
7.0 offset
That's not the offset, that's sounds like the wheel width.
Offset is the number that tells you how far in or out the wheel sits in the wheelwell. It should be a spec that you should know before you buy wheels and tires as it can be very critcal. Chris is asking for it because it sounds like your tires are rubbing somewhere. Most likely on the inside someplace.
Offsets are usually some number between 45 and 30mm for FWD cars. It may be on the back of the wheel somewhere, but if you're going to look for the number there you might as well check your sidewalls for signs of rubbing anyway...
02nissmax
Sep 5, 2015 01:50 PM
perfectmax
Jun 28, 2003 02:52 AM
perrymaxima
Oct 25, 2002 06:58 AM
perrymaxima
Oct 24, 2002 10:04 PM
SWEETSOUND2001
Oct 23, 2002 10:08 AM
