sputtering engine
First thing to do is update your profile with what year and model your max is.
Then start disconnecting the cylinders one at a time until you find the cylinder/s that doesn't affect the cars running and that will be the begining of finding the problem
Originally Posted by animatorelt
i have a 93 SE. is it safe if two cylinders are off, while the engine is turned on? also, is it ok to disconnect them while the engine is running, or must i re-ignite the engine after each try?
The connectors on the coils are easy to do and undo.
You do it while the car is running.
But only disconnect 1 at a time.
Leave the car running the entire time.
That's how I found out I bought a 3 cyl maxima. thenit turned into a 5 now its finally a 6
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
