Had timing advanced and now car idle's rough
Old Dec 30, 2003 | 08:57 AM
94M@X's Avatar
Had my 94 GXE timing advanced to 18 degrees and now the car idle's rough. I made sure to switch to 93 octain gas (used 94 on last fill up) but it is still idleing rough. The car also idle's allot lower now. Used to idle at 1k but now it is just over .5k
Should I just put it back to 15 degrees or is this normal?
Old Dec 30, 2003 | 08:58 AM
internetautomar's Avatar
mod or sell?
put it back and see if it returns to "normal"
Old Dec 30, 2003 | 09:03 AM
94M@X's Avatar
good point, will do!
Just curious, has anyone else had similar results with advancing the timing?
Old Dec 30, 2003 | 03:38 PM
bvtran's Avatar
94c Big Max
It's possible that you didn't do it right if you got one of those advanced timing light gun with a variable setting ****.
Make sure that the **** was set to 18 if that's what you really wanted and make sure it doesn't move while you're setting your timing. Otherwise, if that thing moves, you will not get accurate reading.
Old Dec 30, 2003 | 04:00 PM
AscendantMax's Avatar
your old idle is a bit high... should around 750 rpm after the engine is warmed up.
Old Dec 30, 2003 | 06:13 PM
davebond007's Avatar
+1 to fosgate fan.
Plus it might be time for a tuneup for your car.
Old Dec 30, 2003 | 06:59 PM
MrGone's Avatar
mine was idling at 200 today
Old Dec 30, 2003 | 08:22 PM
bvtran's Avatar
94c Big Max
It should be 700 w/+- 50 according to the FSM.
Old Dec 30, 2003 | 08:38 PM
MrGone's Avatar
yeah, my car isnt to happy right now
Old Dec 30, 2003 | 11:29 PM
shoult's Avatar
Doctor! Doctor! It hurts when I do dis!
Don't do dat.
Put it back.
Old Dec 31, 2003 | 08:40 AM
mod or sell?
With you as a driver I'm not surprised
Old Dec 31, 2003 | 10:36 AM
94M@X's Avatar
Thought advancing the timing was ok as long as you went with higher octain gas?
Old Dec 31, 2003 | 03:43 PM
Aaron92SE's Avatar
NWP Engineering.com
According to the 1992 Maxima FSM, idle should 750 +/- 50.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Ben2003GLE
31
Jul 17, 2016 08:13 AM
Maxboy23
Aug 11, 2015 11:59 AM
mrgooch
Aug 9, 2015 11:00 AM
