Exhaust Rattle after y-pipe install - Please help!
Old Mar 3, 2001 | 05:36 AM
BriGuyMax's Avatar
I installed my Cattman S/S y-pipe about 2 weeks ago, and to make it fit, I had to nudge the rear part of the exhaust system back, and now under very light acceleration, like starting from a stop sign, I hear a vibration that seemes to be coming from the b-pipe area. Has anyone else had this problem, and if so...what did you do to alleviate it. The rest of my exhaust is stock. Thanks!
BriGuyMax
Old Mar 3, 2001 | 07:35 AM
ybelm620
maybe you should reinstall your stock exhuast and or get a new cat-back.
Old Mar 3, 2001 | 12:57 PM
bmfjeep's Avatar
hmmmmm...........................
Not wanting to seem catty just offering some genuine assistance I would start by raising the car up enough to see under the car and pull and push on the tail pipe. The pipes are all mounted on rubber doughnuts and will move to some degree. If you had to push the cat and B pipe back for the Y pipe to fit you have probably pushed a pipe or bracket real close to one of the supports or floor or you may have not installed the bracket which holds the cat in place as it was. There is also a chance the sound you hear is the pipe hitting the sway bar, if that is the case call Brian.
You should be able to adjust the system although you may have to bend one of the supports to give the required clearance.
Dallas
Old Mar 3, 2001 | 01:52 PM
Chunger's Avatar
My other car is a Hybrid
like stated above...
Check the bracket under the very center of the car... I had to put 2 washers to make sure the "B" pipe didn't vibrate against it. This is with a dif exhaust though but I think that probably is the problem.
Good luck.
Old Mar 3, 2001 | 07:08 PM
BriGuyMax's Avatar
Thanks for the help guys....I'll try whatever I need to. I'm putting on a y2k muffler soon...so I'll probably do it then.
thanks again!
JRod28
Dec 29, 2023 09:56 PM
rbuswell
Nov 12, 2016 04:11 PM
umnitza
Sep 1, 2015 01:03 PM
stromm
Aug 27, 2015 04:13 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
