knock knock
knock knock
Ever turn off your car and hear "clink-clink-clink" sound from the engine? Well ... yeah, my has been doing that since I got it ... so I never really paid any attention to it, so I don't know if it's good or bad or doesn't matter. But whats been bothering me lately, is that I'v been hearing that noise when my Maxi is on, but only after she's warmed up a bit. I can't really say if I hear that sound if I'm driving anywhere, because I can only hear it from outside and if my Maxi is parked cause then the wind doesn't drown out the noise. So do you guys/gals think that my Maxi is knockin on me or what? Hope she's not :-(
hmm ... interesting. I recently changed my fuel filter ... is it likely that I didn't install the filter right or something? I didn't do any other work to the engine really (OSCAI & K&N filter, and sorta cleaned the TB) ... wierd ... anyway to fix this problem? for it is really starting to worry me!
Originally Posted by NmexMAX
It's bad. Maybe need a new knock snesor, BUT, first of all, what grade of gas do you use? You must use supreme.
Notice he said it also happens when the car is OFF. Every car that I've ever heard makes this noise right after it is shut off. To my understanding, the clink-clink-clink noise is the exhaust pipes expanding upon warm-up when the car is on, and contracting while their cooling down with the car off.dss42: I'm sorry but your mechanic's a dumba$$
Big D: How exactly is the engine getting air when the ignition is off??
Originally Posted by astil
Big D. if that would happen, your engine would be in pieces...It may be the fuel injectors or...maybe something else.
Originally Posted by Big D
Not really. I know my injectors are bad but if the IACV hose is disconnected and you turn the car off with the key, the engine will be off but it's still sucking in air. You get this loud metal to metal sound.
Originally Posted by nadir_s
******* noobs!
that's the sound of metal expanding/contracting due to the heat the exhaust creates. it's NORMAL.
DC_Juggernaut
Sep 28, 2015 04:07 PM
ballerchris510
Sep 11, 2015 05:29 PM
