Wheel Bearing Question
Old Jan 21, 2004 | 11:44 PM
KRMaxima21's Avatar
I understand that the wheel bearing makes a grinding noise when it goes (believe me I been hearing it ALL winter!!) but I'm trying to figure out is why does the grinding noise go away when you put the car in reverse?? 3 mechanics plus my friend who works on tractor trailers told me it's the wheel bearing but I just can't figure out why I don't hear the sound when I back up. I pray to god I'm not asking a dumbazz question....
Old Jan 22, 2004 | 07:48 AM
eric93SE's Avatar
Think of whats inside the bearing, metal ***** turning in one directions with a broken metal sloshing around, then when in reverse everything sloshes in the opposite direction and might be slightly lower resistance (ie. the broken metal pieces are pushed out of the way).
If you wait too long to replaced it you might damage your hub, this has happened to others on the org.
Old Jan 22, 2004 | 12:38 PM
DMad8724's Avatar
my bearing has been worn since i bought it, back in july, i just plan to pull another hub off a max in a junkyard
Old Jan 22, 2004 | 02:38 PM
Matt93SE's Avatar
STFU n00b!
yup.. either buy a whole spindle from a junkyard, or buy the hub AND wheel bearing from the dealer when you need to replace it.
If you don't need the hub, then treturn it. but if you need it (most likely you will), you'll have it.
Old Jan 22, 2004 | 03:13 PM
KRMaxima21's Avatar
I did it today and the sound is gone !! Went to a friend's garage and took care of it. I see what you said about the whole metal parts going in one direction and not making noise in the other. And I had to get a hub from a salvage yard and a new bearing from an auto parts store. Took it to a auto shop and had it pressed in for 20 and pretty much finished it all in 1 1/2 hours!! Thanx guys for the info and help
Old Jan 22, 2004 | 05:15 PM
internetautomar's Avatar
mod or sell?
Dam and I sell bearings too.
Old Jan 22, 2004 | 08:31 PM
KRMaxima21's Avatar
Now if you sell steering bushings we can talk !!
Old Jan 22, 2004 | 10:11 PM
xveganxcowboyx's Avatar
internetautomar,
I've been hearing a crappy metalic noise for about a week....think a bearings going. What's involved in the fix and how much for parts?
Old Jan 22, 2004 | 10:12 PM
Matt93SE's Avatar
STFU n00b!
damn I wish I could tell you to search!!
Old Jan 23, 2004 | 06:14 AM
mod or sell?
Originally Posted by xveganxcowboyx
internetautomar,
Assuming that it's only the bearing that's fried.
The bearing will run you 'bout $40 + ship
But as others have stated it is quite possible that if you've let it go for too long that it's eaten the hub.
the bearing will need to be pressed/ pounded in IIRC
Old Jan 23, 2004 | 07:56 AM
Matt93SE's Avatar
STFU n00b!
no pounding about it.. it MUST be pressed in.
I've got a 12 ton press, and it was grunting to get my wheel bearings in place..
Old Jan 23, 2004 | 08:48 AM
It's only been making noise (not very loud) for about a week. Doesn't seem like it would have damaged the hub yet. And when I have money to spare I'll donate so I can search. I use the forums enough to justify it.
Old Jan 23, 2004 | 09:03 AM
89maxSE's Avatar
my experiece w/ changing my wheel bearing was a pain in the ***...but thats just b/c I didn't have my plan all thought out...ended up running back and for to parts places and my buddies to get the bearing pressed in then back to the mechanic. Now that I look back, I realized it could have been a lot worse. My mistake
Oh yeah, btw, BUY FROM INTERNETAUTOMART!!! AWESOME DEALS!!!
Old Jan 23, 2004 | 03:12 PM
StRacer718's Avatar
My car makes kind of a high pitched sound when in reverse. Is that also a bad wheel bearing?
Old Jan 23, 2004 | 08:13 PM
bvtran's Avatar
94c Big Max
Save your moneys cuz if you click on the "Donation" button above, you'll see that the owner doesn't want any.
Old Jan 24, 2004 | 01:34 AM
Damn, no search for non-donators and no donation. Lame.
Johnny9595
Sep 3, 2015 05:18 AM
seesole
Aug 26, 2015 11:22 AM
Flores94
Aug 11, 2015 12:53 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
