LSD tranny identification
Old Jan 22, 2004 | 08:39 PM
pezking4's Avatar
I need some help here.
I found myself in the situation to get a reman. tranny for next to nothing. But the problem is I can't figure out if its LSD or not. The id plate has been replaced by a plate that simply says "REMANUFACTURED". Can I tell visually somehow?
-Les
Old Jan 22, 2004 | 08:49 PM
mtcookson's Avatar
the part of the case where the differential is should be a bit bigger compared to the non-lsd dif.
Old Jan 22, 2004 | 09:18 PM
MrGone's Avatar
www.launch2k.com/mrgone
the clean one is for sure a LSD, the dirty one should be according to the VIN tag.
Glad to see some progress
Old Jan 23, 2004 | 10:09 AM
pezking4's Avatar
If it comes down to it I can always take my old one out and compare, but the two trannys are about 100 miles apart right now. I had forgotten about your pics Shawn, I'll pull them up on JMAXIMA's computer when I get to his house since the tranny is sitting in his garage right now.
Old Jan 23, 2004 | 01:35 PM
cneary812's Avatar
the one with the "V" in the code is LSD. ALL VE's Auto and Manuals were LSD's
Old Jan 23, 2004 | 01:41 PM
mtcookson's Avatar
not all of them were
Old Jan 23, 2004 | 03:14 PM
pezking4's Avatar
This tranny doesn't have a code.. if it did I wouldn't have started a thread
Old Jan 23, 2004 | 05:01 PM
James92SE's Avatar
2 VE's are better than one!
Cant you tell if it's LSD by just looking through where the axles connect to the tranny, and if you can see all the way through to the other side it's LSD and if not it's not LSD?
Old Jan 23, 2004 | 07:13 PM
pezking4's Avatar
Good call James. Looks like I've got a non-LSD VE tranny sitting in the garage.
I guess my next question is; am I going to be able to swap out my diff to the new tranny. I wanna keep my limited slip
Old Jan 26, 2004 | 07:45 AM
cneary812's Avatar
from everything I have read the only 2 transmissions for the VE are the LSD ones.
Old Jan 26, 2004 | 11:05 AM
mtcookson's Avatar
if i remember correctly the lsd diff is bigger than the non-lsd so it more than likely won't be swappable unless some fabbing was done.
Old Jan 26, 2004 | 11:37 AM
MrGone's Avatar
If thats the case, then I have had both of them
I think that is for auto, I can't remember.
Les, swapping out the diff should be fun i want pics, even though I've already torn mine apart, still.... yaaay
MaxStock
Dec 5, 2016 05:19 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
