engine control fuse blew out twice
Today the engine control fuse (in the dash afuse array) blew out TWICE..
its 10amp...this happened at a muffler shop where i was having the flex section of the y-pipe looked at for that hissing sound i been hearing.
when the shop guy started the car it didnt start..on instinct i checked the fuses and this fuse was blown...so we changed it and i started it...it ran fine and i shut it off...the shop guy got in the car to get the car on the lift and the fuse blew again..lol ...now after we changed the fuse AGAIN...i didnt let the mechanic start it...since then i drove around all evening and shut off/started the car many times and the fuse is fine...
has anybody else had a problem with this fuse before????
Anyway, check to make sure your o2 sensor is in perfect condition. Other than that, I have no clue what your problem could be.
Originally Posted by vwink182
Might be cause you left the Hawkeye state???
Muhahahhahaha...
Muhahahhahaha...
hehehehh i suppose that could be it
Arron92se, the guy at the shop said the exact same thing!! that the o2 sensor wires were getting spliced up ...but we twise\ted the O2 wires a few times to test that theory, and the car kept running and fuse didnt blow...i'm keeping an eye on this fuse now.
Carry spares, remember you should have reved the engine a bit to see if the o2s wires contacted anything abnormal while being brake torqued
we moved the O2 wires around and wiggled them good to see if the fuse blows again..but it didnt.
pktaske
May 6, 2016 07:49 AM
