2004 Maxima Rear View Mirror
Old Jan 30, 2004 | 06:54 PM
BPBSI's Avatar
Hey all,
I picked up one of these mirror and I want to fix it in my ride, (doesn't have this mirror) .. I found out which pins at the back do what but is there a way I can test this out to see if it turns on? Anyone know what kind of voltage is required? I tried testing it out on a 9 volt battery but had no luck. Any info would be very much appreciated!
Old Jan 30, 2004 | 06:58 PM
CanadianMoFo's Avatar
Thats a good question.
Of course a 9V battery isn't going to work. You'll need a 12V source. One 9V plus two AA's will work.
The downside is that if you put voltage to the wrong pins there is a possibility you could burn out the circuitry in the mirror.
Beyond that advice I can't help ya.
CM.
Old Jan 30, 2004 | 07:27 PM
BPBSI's Avatar
Thanks for the reply,
Fortunately I know which pins to use so I'm all set. I will try the double A with the 9 volt
Old Jan 30, 2004 | 07:35 PM
You can actually buy small 12V batteries at Radio Shack.
Old Jan 31, 2004 | 11:31 AM
BPBSI's Avatar
Well, I tried hooking it up to my ride and it wouldn't turn on. The power source I used was from my fuse box. It was the radio fuse. Funny thing is I smelled something burning. I immediately turned the car off and unhooked the back wires. I know the mirror wasn't frying because I smelled it immediately and it smelled normal. Maybe it was the wires? Too much power? Someone help!!
Old Jan 31, 2004 | 05:40 PM
BPBSI's Avatar
I finally got everything to work.
How do I configure the compass though?
When I press and hold "comp" I have the option of selecting a number between 1 and 15. What does this mean?
P.S Also, does this have tempature reading because when it first boots up I can see the Farenheight and Calcius icons at the top right part of the screen.
Old Jan 31, 2004 | 05:52 PM
No idea. All mine does is auto-dim and have the Homelink buttons built in. Perhaps someone with the package that upgrades the mirror to the same style as yours can help you out.
Maybe visit a dealership and take a peek through the manual of a showroom Maxima.
Old Jan 31, 2004 | 05:58 PM
bluemaxx's Avatar
Moderator GT-R
Toronto probably 10, possibly 9.
Old Jan 31, 2004 | 07:24 PM
BPBSI's Avatar
Oh I see, so I should face north for example and play with the number until it gives me that reading.. Thanks.
Old Feb 1, 2004 | 05:11 AM
bluemaxx's Avatar
Moderator GT-R
There is a diagram/map in section 2-6 of the owners manual. Toronto seems to fall in zone 10, could be 9 though. The closer you get to the North Pole the closer the zone lines get together.
Old Feb 1, 2004 | 05:29 PM
BPBSI's Avatar
thanks all appreciate the help.
Huttig2009
Sep 25, 2015 03:31 PM
Maxilano
Aug 31, 2015 07:33 PM
wingsfan24
Aug 15, 2015 07:35 PM
mrgooch
Aug 9, 2015 11:00 AM
wpr
Aug 5, 2015 03:28 AM
