Car won't start
Old Jan 31, 2004 | 09:15 PM
iansw's Avatar
Car won't start
Car died today. Since I bought it it's started with a simple turn of the key. Maybe 1 second of cranking.
Suddenly, it cranked like the battery was going dead for a second and then stopped cranking altogether.
I checked the CLutch Pedal Switch to make sure it's getting current, and it is. When turning the key I can hear a click underneath the dash (Ignition Switch, I imagine), but nothing under the hood.
Tested the battery - it's fully charged.
Is this a symptom of a bad starter? I always thought when starters went they went slowly....
Any other ideas of what to look into?
Old Jan 31, 2004 | 10:03 PM
s0ber's Avatar
Bang on the starter and maybe it will start up again... I had my car not start 2 times before... one was starter related and the only way I coulda got home was banging on it with a wrench.. 2nd was releated to the ignition getting replaced, but that probably wont help you.
And no they dont just die slowly, this one died on me for no reason while I was at win-dixie... Gave no signs.
Old Feb 1, 2004 | 12:10 AM
happyricefob's Avatar
V^___^V
possibly malfunction engine coolant temperature sensor. i had hard time starting the car. even after i started my car and cruising on the highway, RPM jumped up and down and felt like it was gonna shut down my car. i suggest check that.
also how is the alternator?
Old Feb 1, 2004 | 12:12 AM
iansw's Avatar
Car drives awesome (Hit 12PSI on the way home) once it's started.
Charging system was checked with a multimeter - it was dark so I couldn't see down there to test the starter at the time.
It's definately not the Alternator/Battery.
Coolant Temp Sensor throws a code usually...you didn't have a code?
Old Feb 1, 2004 | 12:33 AM
V^___^V
i had a code, reset ECU and ran for another 1,000 mi, it was fine except gas mileage went down. then it came back again, i figure no big deal again and reset. couple days later my car was having hard time starting and bad revving and bad gas mileage. of course the CEL came back sometimes later and i figure i should fix it. so yea.
Old Feb 1, 2004 | 06:36 PM
iansw's Avatar
Today I tested the wire between the solenoid and the starter with a voltmeter....when tunring the ignition, it reads 10 volts.
That tells me current is getting to the starter, and it's just not doing anything.
So yep - it's the starter....ordered a new one today. Thank god I'm a 5spd and can just make sure I park on hills.
Old Feb 1, 2004 | 10:40 PM
s0ber's Avatar
Shoulda banged on it
Old Feb 1, 2004 | 10:44 PM
iansw's Avatar
I did for a good 20 minutes....REALLY hard at one point...no dice...She's dead.
Old Feb 1, 2004 | 10:59 PM
s0ber's Avatar
may it RIP then.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Btheman80
May 1, 2018 04:03 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
BobMax
Aug 15, 2015 12:35 PM
