wanna upgrade the cluster bulbs 2bright....
hey i have a 96 max se with white faces and i wanna change my blubs 2 super white member seening them on here before but can't find it .. what bulb u guys use again??? thanx
Originally Posted by Nismo
Im going to try the 5 polargs. I only found 1 polarg left in my garage so I guess its time to buy more. Originally I was going to do LEDs but the leds are too narrow of a beam
they light up from the side as well as the top. If only i had a digi cam.
I got the blue ones, they are brighter than any other blue bulb i tried.
Originally Posted by z-dan
Try the Single LED Wedge Base bulbs from http://www.superbrightleds.com
I got a bunch of those right here but I wasnt shure if they would be bright enough for me. How do those compare to the brightness of a polarg 194?
Originally Posted by Sped
Thanks z-dan I just placed an order with them. The 194 bulbs are the same in the 99 as they are in 95-97 right? just wanted to make sure i got the right ones.
Sped if you can't cancel the order you can always use them for the door lights or sell them here on the .org, sorry again.
crap hah.. I wish there was a way to call them and cancel that order. I placed a 2nd order with them just now and in comments i asked for my 1st one to be cancelled. Also going to email them in the 1st confirmation email they sent to try and cancel it because I selected overnight shipping and im going to get raped on that if i do have to return the wrong bulbs. ah well live and learn.
RI-Max - www.superbrightleds.com
BTW- I just put in 5 polarg hyper whites in and it has a slight Pink/Red tint to them so I took them out and put the stock bulbs back in.
I tried the 194 LEDs I had and they are not bright enough for me, even the 6led 194(the brightest) isnt bright enough for me. Oh well
with polargs it was bright like the pic above but it had a slight red tint to it
with PIAA hyperwhite it looked too blue
with white 6LED it looked like hyperwhite like that pic above
with clear bulbs it looked yellowish
with amber bulbs it looked amber
with stock bulbs(clear bulb with a blue rubber condom cover) it looked white which I left it at since I wanted pure white
pics of blue leds are in here
http://forums.maxima.org/showthread.php?t=282857
white led
the white led pic didnt work.. wat if the single led from www.superbrightleds.com were used? will it look like the blue ones in that thread.. but wit a white color? cuz i kno that you said that you used 6 led.. so i was wonderin wat the single would look like.. yeh.. that pic didnt work.. hmm
diz
diz
__________________________________________________ ________________
What Kind of Bulb does the Gauge Cluster Use?
95-97 Use 194 ( I have changed mine and i have a 97)
98-99 Use 74
diz
diz
I tried installing the #74 blue leds in today.. they didnt light up.. so i put the regular bulbs back in. any idea on what could have caused this?
"They have a built in current limiting resistor and diode to protect the led from reversed polarity installation. If you plug them in and they don't light, turn them around and they will light."
tried it again and figured out my dumb *** forgot to hook the dimmer back up while testing.. it all works now. i noticed that i think i need a wider angle on the led because i have some spots that arent as well lit as others.. any suggestions?
knight_yyz
Nov 1, 2015 01:34 PM
