Replacing Rear Break Pads...Help
I've changed lots of brake pads over the years, but this is first run at the Maxima. Can someone tell me how they collapse the rear pistons once the caliper is removed so the new pads will fit?
Having a bit of difficulty.
thx.
thx.
Originally Posted by 1FSTMAX
You need to turn the piston clockwise so that it will go in.
Where can I get this "cube tool" that everyone is talking about....sorry for all the questions.
thx.
Originally Posted by TheCirque
How difficult should it be to turn? I can't do it by hand or screw driver. So the old C-Clamp method won't work, huh? I need to apply pressure and turn at the same time?.
thx.
thx.
thx.
thx.
Nah you don't need fancy tools. You can do it with a pair of channel lock pliers. Just grab the piston, and turn it.
If you have an older car I would suggest buying the tool. Any Napa or local parts store will have it. My rear calipers were basically frozen. It took a lot of grunt work to turn them. The tool was necessary for my older (95) high milage car.
Mine are hard to turn as well (even with the tool). I'm gonna pull them all off and rebuild them soon.
Hell, I should've done that last September when my tranny blew up...my car's been sitting in the drive way motionless since then.
If you really can't get them turned in, you may want to try loosening the bleeder valve for that caliper...be warned, though...you'll have to bleed that caliper after doing it.
The tool is inexpensive and easy to find. The one I found is a cube shape with different pin configurations on each face and fits onto a 3/8" drive ratchet or extention. Keep an eye on the dust boot while you are turning the piston back in because it can stick to the piston and tear if you are not careful. Mine were stuck so I used a very small flathead screwdriver with the tip dipped in brake fluid to free it and to lubricate it. Worked like a champ but the piston was a little tough to turn.
jskirwin
Jun 8, 2016 08:49 AM
Huttig2009
Sep 25, 2015 03:31 PM
Maxilano
Aug 31, 2015 07:33 PM
BobMax
Aug 15, 2015 12:35 PM
