Creaky Steering???
Old Feb 10, 2004 | 07:19 PM
PoePoe2797's Avatar
Creaky Steering???
Recently, starting 2 days ago my steering started to get real creaky....kinda like a wood floor creaking or like a door creaking. At some points it gets quite loud. I also noticed this happens loudest when I'm at a complete stop or moving at like 1-5 mph. I thought it was my PS, but I checked and no leaks and reservoir is full. It almost sounds as if something isn't lubricated right....can't really explain better than the door or wood creaking. I also noticed an increase in minor "clunking" ...such as on and off the throttle or when going slow. I don't know if its related. I know the creaking is definatly coming from somewhere near the wheels because if i stick my head outside the door I can hear it a lot more and I checked CV's and boots are fine and never had a problem with them. Also, it doesn't matter if the car is on or off, still creaks while turning the wheels. Anyone know what this may be? I hope its not expensive cuz im broke
Old Feb 10, 2004 | 08:25 PM
WHOS UR DADDY's Avatar
Have the same thing, its the strut bearings. You gotta take apart the entire suspension and get new ones. Its a pain in the a$$ and its not worth it. The canadian DIY (i forgot the name) website has instructions.
Old Feb 11, 2004 | 05:04 AM
PoePoe2797's Avatar
Your sure about that? It's wierd this came out of no where.....any your sure its linked to the steering?
Old Feb 11, 2004 | 05:44 AM
knight71's Avatar
I had the same problem..is it a clunk clunk noise when turning the steering wheel..then definetely it is strut bearings..parts are cheap..labour is about one hour.
Old Feb 11, 2004 | 09:15 AM
PoePoe2797's Avatar
Maybe, but i'm more worried about the creaking right now and what I want to know is if the strut bearing causes this?
Old Feb 11, 2004 | 09:55 AM
MadChef's Avatar
I just had that problem fixed. My CV (constant velocity) boot (right side) had come off and I needed a new right side CV shaft.
I will say that they told me it was "noisy struts" at first, but that nothing was wrong with them (other than them being "noisy"). I didn't have them fixed, but the new shaft did the job.
I guess check to see if your CV boots are ripped/torn.
Old Feb 11, 2004 | 06:34 PM
PoePoe2797's Avatar
Checked the CVs already and boots are fine
Old Oct 29, 2011 | 09:43 AM
sickwitit's Avatar
resurrecting this thread from the dead like a zombie! seeing if over the years people may have experienced this. I have a 99 max, recently when i am parked and start the car, i kind of hear a groaning noise. I will be completely parked, and when reversing out of the driveway or turning my steering wheel i hear like a "creaking" noise, once i reverse out and don't turn the wheel, i can drive normally and the noise goes away. When i make the first turn after starting the car, it groans, and the second turn as well, but then goes away after that and i can drive just fine. Sounds like its coming from the front passenger side. It recently started a few days ago, it just started getting cold here in tx so i don't know if that makes a difference but it never did it when it was warm. any info you guys might have on this?
Fbana41
Aug 29, 2016 12:18 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
