Help!!! Clutch Failure??!!
okay so went out to start my car and the clutch falls right to the floor and won't come back up on it's on...it's like dead weight...and I just had my clutch replaced with a racing clutch 2 weeks ago...any theories as to what's happening here?
I need a response asap guys. :-)
Check your clutch master cylinder fluid level, if low, top up..Could be a leak in cylinder, You may need a new one.
Question for you guys... When you release the clutch pedal, what causes it to return to the top?
Is there an internal spring in the master or slave cylinder, or is it the slave cylinder pushed back in by the release fork under spring pressure from the fingers on the pressure plate?
I would check your fluid level, but also check that the slave cylinder is still bolted to the tranny bellhousing and engaged into the release fork correctly...
And if you can move the release fork by hand then soemthing us wrong
I certainly wouldn't count that...
If it really is the fingers of the pressure plate, wouldn't the TO bearing maintain (even light) contact with the fingers? If so, the TO bearing will spin continuously...wouldn't this wear down the TO bearing?
The pressure plate fingers push the throwout bearing down the tranny input shaft, which pushes on the release fork, which pushes on the slave cylinder piston etc... With nothing pushing back with any amount of force the throwout bearing is not being held against the fingers, and it seems that it would be able to stand just clear of contact. Even if there is contact there is little to no wear. It's a bearing - it's not metal-to-metal contact.
Just like disk brakes - there is nothing pushing the pads apart when you let go of the brake - the pads just seperate because the disk pushes them away. Any residual contact as you are diriving down the road is too light to cause any problems.
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
carlosvq30
Sep 26, 2015 09:44 AM
